Battery gets REAL hot when both cables attached...
Guys, just drug home another challenge. Bought a 95 coupe ,non VTEC that has been sitting up for a LONG time. Previous owner said field mice had chewed on the wiring harness somewhere and now when cables attached the battery gets hot. Am headed out to trouble shoot in a bit and was wondering best way to trouble shoot. First glance underhood shows no obvious visual problems.
What fuse or fuses can I pull to split the electrical pathways. Can you separate, underhood, interior, trunk to help narrow down where the problem may be. I think the underhood fuse block would be the key place to start......thanks.....
Finally found two problems, brake light switch pad had dried up and fallen out, and a critter had chewed into one side of the brake lights and some wires were shorted together. New stop pad and spliced leads back together has solved cooking battery......thanks..
EusebioSam19
Aug 12, 2012 01:29 PM
aware
Jun 22, 2005 01:36 PM
Civic138
Jan 4, 2005 05:59 AM
