Z6/Y8 help and instruction is need asap!!
Old Jun 13, 2011 | 08:59 PM
mcdonoughEk00's Avatar
Icon6 Z6/Y8 help and instruction is need asap!!
So I have a 2000 civic Ex with a d16z6, and a y8 trany. Chipped Ecu with a p28 base map. I have a local tuner (my friend) The head has a bent valve or something so i found a good deal on another y8 head. So i was wondering what all i needed to get it to work.
1. Ok so will the z6 dizzy work with the y8 head? ive heard i wont work but can u can modify/ cut it and it will work. I originally bought a 0b2 to obd1 adapter to work with the z6 dizzy i kept my stock harness.
2. Will my z6 vtec solenoid work on the y8. The y8 head doesnt have a solenoid. And i know i need a head gasket obviously.
3. Will my skunk2 intake manifold fit the y8?
Ive heard the D-series is pretty interchangeable just wandering how much.
Old Jun 13, 2011 | 09:00 PM
Default Re: Z6/Y8 help and instruction is need asap!!
This is my daily so i need to get it back on the road as soon as possible and cheaply if possible. i found a y8 dizzy for 60 from a guy in Michigan.
Old Jun 13, 2011 | 09:17 PM
NikoEJ2's Avatar
Idk a lot about single cams owned one for about 3 months but be sure to resurface everything including the block cuz Honda blocks warp very commonly and I'm almost 100% your manifold will fit I would also get a dizzy to match your head best option don't cut corners man always ends up bad quality is priceless
Old Jun 13, 2011 | 09:25 PM
NikoEJ2's Avatar
O and the solenoids are different Just match everything w your head and you'll b fine
Old Jun 14, 2011 | 05:07 AM
Cresendo's Avatar
Get a y8/y7 dizzy if ur obd2 or d15b7 dizzy if ur staying obd1 for the y8 head vtec solenoids are different go get the one to match the head manifold will bolt right on
Old Jun 15, 2011 | 11:20 AM
Will a Z6 VC fit on a Y8 head?
Old Jun 15, 2011 | 12:36 PM
24TEN's Avatar
PHANTOM MENACE
Z6 distributor internals will work but the distributor housing will not bolt up as is. Modification is necessary or housing swap can be done.
Solenoid is not interchangeable.
Manifold is interchangeable.
Valvecover is interchangeable.
Old Jun 15, 2011 | 03:50 PM
I have a Y8 head with a aem adjustable cam gear will it fit on a Z6 head
Old Jun 16, 2011 | 06:19 AM
24TEN's Avatar
PHANTOM MENACE
If you're referring to using the cam gear on the Z6 head then yes it is interchangeable. Make sure you reference TDC according to the respective head, it's been a while but I believe my Skunk2 cam gear had separate marks for the Z6 and Y8.
Old Jun 17, 2011 | 07:03 PM
picked up a z6 head today for 50$ ill post some pics let ya see it see what ya think
Old Jun 17, 2011 | 07:34 PM
The rocker arm ***. looks pretty dirty i shouldn be too worried about it should i?
another Question... are there suppose to be multiple studs for the intake manifold to bolt onto? this head only looks like it has 2 or three. can i just run bolts into the holes or should i buy some studs?
Old Jun 17, 2011 | 07:35 PM
blackberry pics sorry for the poor quality
Old Jun 17, 2011 | 07:37 PM
do u think this head would be ok should i take it to a machine shop? keep in mind im runnin a turbo on light boost.
Old Jun 18, 2011 | 07:26 PM
bump
Old Jun 19, 2011 | 04:37 PM
FML
Old Jun 19, 2011 | 06:11 PM
Blacknight117's Avatar
There should be at least 9 studs that mate the intake mani to the head. To be safe, buy new studs, shouldn`t cost more than $20 if that much. As for machining, I would say since your running a light boost, I would go and have it machined. It won`t hurt it. Than Than just make sure you get any remaining intake mani gasket off so the new one goes on clean. Lastly, the rocker, in theory can be cleaned with some carb cleaner. If you do do that, this may sound weird but, have the head upside down while you are spraying so the nastiness doesn`t get into the head. Go side to side about 3 times, let it drip and dry, than do that once more. Than you can take a few shop towels and wipe the crud off.
thatseemslegit
Aug 30, 2015 01:45 PM
ekcivicb16
Jan 11, 2013 04:45 AM
TehMoonRulz
May 30, 2005 08:51 AM
BOOSTEDgreeneg
May 9, 2005 07:03 PM
BMac86
24
Oct 28, 2003 04:04 PM
