Del Sol shifting question
Old Jun 13, 2011 | 11:43 AM
*del_slow*93's Avatar
Default Del Sol shifting question
My car is hard to get into gear and sometimes won't go in at all while the car is running. If I shut the car off it will go into gear. I've gotten different opinions from people. 1. my tranny is bad. 2. My throwout bearing is bad. 3. My clutch is bad. 4. Shift linkage is bad. anyone else have this problem and if so what was wrong?
Old Jun 13, 2011 | 12:04 PM
94EG8's Avatar
Seagull Management
Default Re: Del Sol shifting question
It's a clutch release issue. It's one of the following:
-Bad clutch master cylinder
-Bad clutch slave cylinder
-Bad throwout bearing
-Clutch disc spit a spring
-Pressure plate is messed up
Start with the first two since they're more probable and a lot easier and cheaper to fix.
Old Jun 13, 2011 | 02:26 PM
mrchouayang's Avatar
i had that issue as well when i used to have my delsol.. couldn't figure out what was wrong.. but eventually it just started working again.. crazy stuff
Old Jun 13, 2011 | 03:55 PM
Go_Race_Your_Self's Avatar
Two Piece
Does it grind when you shift when car is running?
Old Jun 13, 2011 | 04:54 PM
Jimster480's Avatar
^This
dragonkx
37
Jun 2, 2010 09:04 AM
tigersball
Jul 9, 2008 09:45 PM
joedeo72
Jun 7, 2008 01:14 PM
JFG Kevin
Apr 12, 2006 01:56 AM
allenp
Oct 25, 2002 10:51 AM
