93 Accord EX CEL 43
Old Jun 13, 2011 | 09:56 AM
jarsac13's Avatar
Default 93 Accord EX CEL 43
Throwing a 43 from the check engine light which as I've read is hondaese for replace your O2 sensor. The car just hit 120k on a F22A6 engine and I was wondering two things. The CEL only comes on after being on the freeway for about 5-6 minutes and it's always the 43 code.
Could it be anything else other then the O2 sensor or is that the only culprit.
Also having problems locating the sensor itself, I pulled off the heatshield today to see if I could find it from the schematics I've seen on these forums and other ones but I didn't see it.
Thanks in advance.
Old Jun 14, 2011 | 12:39 AM
holmesnmanny's Avatar
Default Re: 93 Accord EX CEL 43
It normally would be under the car inside the exhaust pipe just before the catalytic converter.
Old Jun 14, 2011 | 06:06 AM
StreetsideStig's Avatar
^Yes. And the other should be on the lower front of your exhaust manifold. It's really odd that it isn't there.
Old Jun 14, 2011 | 10:50 AM
jarsac13's Avatar
Thanks, I found both of them. Now the fun begins..
Old Jun 15, 2011 | 04:41 AM
If you're taking one or both out, I would recommend picking up one of these from the parts store:
It's an 02 sensor socket. The slot is for the wires. It's a ton easier getting them out.
Hit it with some freeze-off junk a couple hours ahead of time, too.
tdsilk
Nov 30, 2011 08:39 AM
cholder919
Oct 19, 2011 12:41 AM
lowered94accord
Apr 6, 2007 10:17 AM
Cuong-nutz
26
Nov 7, 2005 10:04 PM
