valve seats chipping
Old Jun 13, 2011 | 04:44 AM
061000rr's Avatar
Default valve seats chipping
what are you guys doing and were are you getting your machine work done at to get valve seats fixed? and what is the main cause of them doing this? about half the intake valve seats have big chips missing.
Old Jun 13, 2011 | 05:04 AM
JConto's Avatar
Default Re: valve seats chipping
I think your hydraulic lmas might be bad. You might have to switch to the new ones (spring based).
Old Jun 13, 2011 | 06:36 AM
061000rr's Avatar
it has all new type r lma's
Old Jun 13, 2011 | 09:44 AM
tepid1's Avatar
What springs are you using?
Old Jun 13, 2011 | 10:18 AM
061000rr's Avatar
crowler springs and titanium retainers
Old Jun 13, 2011 | 10:47 AM
cibao2ner's Avatar
some people grind the rockers in bottom....
Old Jun 13, 2011 | 11:04 AM
tepid1's Avatar
Do you know the spring pressures? What cams?
The reason I ask is because if the spring it too stiff, if you have valve float, or if you're over revving the engine you can beat up the seats pretty bad. You'll see a lot of people switching the valve seats to a softer metal, like bronze, to promote seal and prevent issues like this.
Old Jun 13, 2011 | 11:14 AM
061000rr's Avatar
were ever i send the head im going to have the spring pressure ck. type r cams. shifted at 10k and had prob 40-50 hits on the motor. little bit of dyno time. how much life do you get out of softer seats? or does the use of race gas help with the lead?
Old Jun 13, 2011 | 02:06 PM
xtremvw's Avatar
we had similar problem exhaust valve spring were too soft and valves were floating and the seat was moving since the valve was hitting the seat since it was not controled by the spring
Boosted_B_Series
Jan 26, 2012 04:12 AM
phbrush
Jun 26, 2009 05:21 PM
streetrage
Apr 11, 2006 10:38 AM
swpdb16
12
Nov 16, 2004 02:55 PM
stizzit
Aug 31, 2004 09:36 PM
