Header leak not sure how to fix
Old Jun 12, 2011 | 01:09 PM
3s1k's Avatar
Default Header leak not sure how to fix
I thought the leak was coming from the manifold gasket or the donut gasket but when I got it up onto the lift I noticed it was coming from there the 2 peice header come together. Since there is no gasket how could I seal this up. I noticed it was leaking when I was driving you can smell exhaust inside the cabin. What do you guys recommend? 2 ideas I had were exhaust wrapping the header or removing the 2 pieces and putting hightemp RTV on all the tubes.
Thanks in advance
Old Jun 12, 2011 | 01:11 PM
FlewByU352's Avatar
Default Re: Header leak not sure how to fix
What if you sprayed copper gasket in there?
Old Jun 12, 2011 | 02:30 PM
3s1k's Avatar
remove the pipes first then spray it and re-assemble? Eventually will the gasket melt away?
Old Jun 12, 2011 | 02:44 PM
FlewByU352's Avatar
Did you remove the springs before taking the picture or do you just not have them on there? If you don't have them on there then that is definitely why you have a leak.
grumblemarc's Avatar
The Grumpiest
How about install the missing hardware that it looks like you don't have?
Old Jun 12, 2011 | 02:49 PM
3s1k's Avatar
Nope it didn't have the springs when I got it. I guess they are more important than I though. I figured since it's bolted on both ends with would move. How do they keep them from leaking?
The Grumpiest
Clamping force.
Old Jun 12, 2011 | 08:24 PM
MR.johnson's Avatar
Heat will expand the inside pipe. Get some springs. Should seal up fine.
Old Jun 12, 2011 | 09:43 PM
mouab18c1's Avatar
Weld it.
Old Jun 13, 2011 | 07:29 AM
MR.johnson's Avatar
Originally Posted by mouab18c1
Weld it.
why? it will seal fine if its installed properly.
Old Jun 13, 2011 | 11:28 AM
mouab18c1's Avatar
It's a suggestion. What else?
Old Jun 15, 2011 | 06:46 AM
dntnedvtec's Avatar
Weld it.
I agree. Buddy's Tri Y had a similar deal. Got it welded. No more leak.
I also agree. But he doesn't have the hardware to correctly fix the problem..
Old Jul 10, 2011 | 06:33 PM
3s1k's Avatar
I got 4 springs today and installed them also as a back up I put some RTV inside all the tubes. I just wanted to make sure it was sealed because I don't feel like crawling under again and wasting 2 hours of my sunday working on it.
I see what you mean with the springs, even with the tubes on there was a little back and forth play on them. With 4 springs it won't be able to move on its on. Hopefully it works, just giving it 24 hours for the RTV to dry up and I can drive my baby again. It's been at least a month, I will miss getting high on exhaust fumes from long drives though hehe J/K
Old Jul 10, 2011 | 07:29 PM
BrownDx's Avatar
RTV; interesting..
Old Jul 10, 2011 | 07:48 PM
3s1k's Avatar
Originally Posted by BrownDx
RTV; interesting..
Is that not a good idea? It was Permatex High Temp RTV silicone.
Speedy5966
Nov 12, 2017 01:26 PM
crazyboy
Oct 17, 2011 09:17 AM
1994PreludeSi
Jul 11, 2007 10:33 PM
gtowni3
29
May 12, 2005 03:14 PM
cccccccc
Jun 19, 2003 11:03 PM
