b16 cx at the track
well i took the civic to the track yesterday i have a 92 civic cx with a jdm b16 it has a skunk2 exhaust and a obx intake manifold and a act stage 3 clutch other then that its all stock
first run launched at 3500rpm
60ft 2.48
1/4 15.39
1/4mph 89.9
second run launch at 6500rpm
60ft 2.32
1/4 15.13
1/4mph 90.3
third run launched at 7000rpm
60ft 2.61
1/4 15.61
1/4 91.3
here is a couple pics of the car at the track
60ft 2.48
1/4 15.39
1/4mph 89.9
60ft 2.32
1/4 15.13
1/4mph 90.3
60ft 2.61
1/4 15.61
1/4 91.3
my first run i launched at 3500rpm and it wheel hopped really bad but when i launched at
6500 it still wheel hopped but not as bad plus i was running 35psi in my front tires anyone have any advice for the next time i go THANKS
Lower your tire pressure to around 18-20psi I'd try slipping the clutch rather than dumping it. 2nd gear burnout to heat up the tires good. good investment would be some drag radials. should be good for some mid 14's if you can get it to hook. Lots of seat time and you'll get it dialed in.
14 inch bfg drag radials. 205 50 14. they fit on steelies so its a nice cheap track tire that you can drive to the track on but since you can easily get a set of steelies you wont have to worry about putting them on your regular rims. also that size tire works out perfectly for a stock b16 trans. i trapped 98 mph in my b16 with them and i finished almost at the end of 4th gear.
92-LS-Civic
Aug 26, 2004 10:19 AM
jlh81
Apr 30, 2004 11:40 PM
PotatoePAPA
Jun 1, 2003 09:57 PM
