VAFC or SAFC??Which one is better for my Engine??
Old Jun 12, 2011 | 06:13 AM
Honda_8987's Avatar
Post VAFC or SAFC??Which one is better for my Engine??
My car is Honda Civic SI year 88-91, engine ZC DOCH D16 A9, ECU PM7.
I just want to know that which one is better for my engine.VAFC or SAFC??
I'm not sure which one is more suitable/better for my engine.
I need suggestion about this.
Thank You.
Old Jun 12, 2011 | 07:47 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: VAFC or SAFC??Which one is better for my Engine??
VAFC is for VTEC engines and SAFC is for every other engine out there. If you have a bone stock motor you will not see gains by using a controller.
Old Jun 12, 2011 | 10:25 AM
93grayeg's Avatar
Neither
Old Jun 12, 2011 | 11:45 AM
TJChad's Avatar
If it was 1999 then you might get alot of opinions on this. However, save your money.
Old Jun 13, 2011 | 06:15 AM
Honda_8987's Avatar
Thank You Guys for the opinions.
Now i'm using VTEC B16 A intek manifold, do i need to change back to the original intek manifold so that i can install the SAFC?
And can it works very well?
Old Jun 14, 2011 | 07:21 AM
DVDr's Avatar
Get which ever one is cheaper.
If you get a VAFC, you wont use the Vtec point adjustment feature.
VAFC=SAFC+Vtec point adjustment.
In your case you dont have a Vtec point to adjust, so either one will work.
Ideally a SAFC 2, is the nicest one for your setup ( but either safc 1 , 2 , neo, , vafc will work ).
Intake manifolds wont matter, either unit will go connected via ecu harness. So hardware doesn't matter .
side note alot of people prefer chipped ecus and a full tune. But if you have minor mods. I find the SAFC a great tool.
Old Jun 17, 2011 | 04:16 AM
Honda_8987's Avatar
thanks to u guys and the opinion....bt i have no pm7 ecu diagram,to install SAFC,i need u guys help...
Old Jun 20, 2011 | 09:54 AM
JDM-JAMES's Avatar
none
Old Jun 22, 2011 | 04:12 AM
BobbyRodriguez's Avatar
Is 200 worth your motor? Don't get me wrong they work for n/a no boost tables
Traser
Nov 17, 2006 11:30 AM
ldanphanl
Mar 10, 2005 09:38 PM
mz3bo
Feb 27, 2003 02:27 PM
mz3bo
Feb 27, 2003 08:38 AM
SuperRice
Apr 29, 2002 04:37 PM
