hey guys i have check engine light woes and need help
hello, and thank you for all future help................For the past month i have been having some issues. i have a d16y8 swap fully converted to obd1 with a rywire like standalone harness. I got the car tuned and it was running pretty good for a night or two but was throwing 2 codes. IAT and VSS. so i was stuck in limp mode when i plugged my vss back in i was able to go to rev limiter, and i replaced the iat with another UNKNOWN working one. what made me start messing around with the IAT and other things is the car is running super rich to the point where it sounds like the car is misfiring under acceleration and sometimes idle.
my problems are as followed
1. i cant check my codes anymore not even when i grounded d4 out (plz help me)
2. i am running super rich is there anyway my computer can like detune?
3. is there any other way i can get the computer to check the codes?
the check engine light comes on then goes off when the fuel pump primes but after about 6-7 seconds it turns on again and never leaves
thank you
thank you
so you sent the new motor harness with the old motor harness to rywire? and they made your new hybrid harness? or did you get it used from someone? sure the ground where you are grounding the ck eng wire to is good? and you know it has to maintain continuity to ground in order to flash the codes right? did you have the light on before it was tuned?
wow thank u so much for quick response, the motor harness is a rywire clone it is brand new but wasn't made from them, the check engine light was working previous and i would ground it to the same spot (yes i know it needs continuity) the last codes it threw were IAT and VSS like i stated
my old hatch did this, i had to have the chip re-tuned and it was ok after that.. i had the battery disconnected for like 3 days due to dropping the transmission, i guess when the ecu dosent get power for long enough it resets the tune, thats what happened to me anyways.
Need help help also i cant start a post or new thread. I guess this the
Way i can ask for help same thing check engine light out of
95 gsr somebody show me how to check cant figure it out
What kind a reading im getting first one i get two bold blink
And then it follow faster blink which is 985, is there anbody
Out there have the same issue, i really appriciate any help
o yea was the cel on immediately after the swap was completed? if so that would indicate problems in the harness conversion. if they turned on later it would indicate loose connections or inadvertent damage.
thank u guys so much, well my map took a ****, and then i think my starter took a **** the motor doesnt even click but someone told me to check the ignition switch.........i did and i found two cut and messed around with wires
so i am buying a new cabin harness for ***** and giggles, a barometric pressure sensor, new main relay, new ignition switch, and new IAT along with the newly aquired MAP i got i will update you guys and post pics
EFJDM1
Sep 23, 2016 10:33 PM
xlusiveracer
45
Dec 17, 2011 12:59 AM
honda_ek9
Engine Management and Tuning
13
Jan 8, 2009 09:06 PM
TastyTuner
Mar 15, 2006 05:29 PM
rad_thundercat
Apr 21, 2004 08:20 PM
