Classic Hondas All Pre-1988 Hondas.
1987 accord hatch trans leak
Old Jun 11, 2011 | 09:54 PM
b345tifall's Avatar
Default 1987 accord hatch trans leak
i have a transmission leak some were under the starter cant find it. when its running and i but it into drive it start leaking under the starter somewhere i took the starter out to try to find the leak could not find it need help
Old Jun 12, 2011 | 05:27 AM
poorman212's Avatar
Default Re: 1987 accord hatch trans leak
Can I guess this is an auto trans?
And this really doesn't matter, just wondering- DX, LX or LX-i
Old Jun 12, 2011 | 10:51 AM
b345tifall's Avatar
yeah its a an auto i think it coming out of coolant hoses that go to the trans that are under the start but i don't know and don't know how to fix it
Old Jun 14, 2011 | 05:54 AM
88LXi68's Avatar
first you need to determine what you are leaking. Is it oil, coolant, or atf? If it is oil, and you said it is coming from around the starter it could be a valve cover gasket, distributor o-ring, or going lower it could be rear main seal, or even the drain plug on a manual trans as that uses regular motor oil. If it is coolant, check all your hoses and your thermostat housing.
Old Jun 14, 2011 | 02:47 PM
poorman212's Avatar
As stated, now we need to know what kind of fluid this is....title says trans leak, so can we assume this is trans fluid?
There is a trans cooloer pipe that runs "under" the starter and then connects to the trans, kind of near the speed sensor....went to refresh my memory on the 88 LXi auto, the only auto in that gen that is home right now.
How to fix? Well that is going to depend on if the metal pipe had a hole in it or is the rubber hose broken..
Old Jun 14, 2011 | 08:07 PM
b345tifall's Avatar
well i think it coming from were the coolant pipe meats the trans but it transmission fluid that is leaking
Old Jun 15, 2011 | 11:24 AM
88LXi68's Avatar
Sounds like it might be the rubber lines running from the trans cooler. Double check that that the clamps are on where they should be and if they are just go to your local parts store and get some rubber hose and replace them.
Old Jun 15, 2011 | 03:24 PM
poorman212's Avatar
Check the bolt/fitting. I think, none of the auto's in that gen are home tonight, the bolt is a banjo bolt that would have washers sealing it.....much like how a brake hose connects to the calipers....
Also, IF you go down the hose route. BE SURE the hose is rated as trans cooler hose. DO NOT use anything else. Gates part number is like 27058 for 5/16 and 27059 for 3/8. Memory tells me that line is closer to 3/8 id.
Old Jun 17, 2011 | 11:06 AM
b345tifall's Avatar
thanks poorman for the help fix it it was the washers the washers were on wrong
Uploaded with ImageShack.us
Old Jun 17, 2011 | 02:43 PM
poorman212's Avatar
Anytime, glad to hear it was "fairly" easy....good luck.
Looks like a light blue color, sun kind of makes it had to be sure....I use to have a light blue 86 DX.....something about five 3rd gens the wife didn't like so I had to let it go.
OriginalSandman
Nov 9, 2015 04:51 PM
johnzy00
Honda Civic (2006 - 2015)
Jan 9, 2012 06:45 AM
coronadrinker
Oct 15, 2006 02:19 PM
civicboy95
Dec 23, 2004 02:29 PM
