All four stainless lines leaking
Old Jun 10, 2011 | 08:58 PM
h-duced's Avatar
Default All four stainless lines leaking
I went ahead and did goodrich stainless lines got everything tight and all four are leaking where they bolt into the hard line. I don't understand why. They are supposed to be a mechanical seal right? Should I put teflon tape on the fittings or what? Can you even use teflon with brake fluid? I double checked everything as well I know they are tight.
Old Jun 10, 2011 | 09:05 PM
h-duced's Avatar
Default Re: All four stainless lines leaking
Nevermind. Just found out that you really got to crank these puppies down problem fixed
Old Jun 11, 2011 | 04:43 AM
redm3turbo's Avatar
How do you like them? Ive read you get instant pedal difference...and alot of people like them.
I just changed out a metal brake line....because it was leaking, but the brakes are rock solid, so I cant see them getting any better then that.
Old Sep 14, 2011 | 07:32 AM
h-duced's Avatar
I really dont feel a big difference. Nothing special.
Old Sep 14, 2011 | 08:23 AM
kyden's Avatar
you shouldn't have to "crank down" on them. the washers seal it.
daboy155
Suspension & Brakes
Sep 18, 2017 06:59 PM
5spdfrk
Suspension & Brakes
Oct 1, 2009 08:56 AM
InvaderTrax
Jan 10, 2007 06:50 PM
OKSolSi
Apr 20, 2004 08:13 PM
