Loud clicking gone...quieter clicking noise left behind.
Old Jun 10, 2011 | 02:29 PM
bigjoe502's Avatar
Default Loud clicking gone...quieter clicking noise left behind.
I have a Canadian 1994 Civic Si Coupe. So an EX for the boys south of the boarder. I replaced the Passenger side CV because of a loud clicking noise when turning. Now what is left is a softer clicking noise that is most noticeable inside the car and when turning. What way I turn dosen't seem to matter. The car sat for a while and the front rotors are pretty rusted and make grinding noises when braking. Any one have brakes make noises like this when badly rusted? Or if you have any other Ideas please feel free to volunteer your info. The car just passed a safety test so I am assuming the suspension is good.
Thanks
Old Jun 10, 2011 | 03:56 PM
FTNW's Avatar
Default Re: Loud clicking gone...quieter clicking noise left behind.
You should have replaced the whole axle
Old Jun 10, 2011 | 06:30 PM
virgineg6's Avatar
Mexico? Lol jk!
If you have driven it a bit and the rotors are still rusted they need to be replaced, while your at it might as well change the pads. Might need to replace the drivers axle.
Old Jun 11, 2011 | 04:51 AM
redm3turbo's Avatar
most safety tests dont do much suspension testing...normally the check the ball joints/tie rods, (by pressing on the tire top and bottom and side to side) then check tire depth...and then just look underneath for rips/leaks/etc...
alot of times depends on rims, alot of mechanics just reach the gauge in...to check the remaining brake life.... not pull the tire off and open the caliper.
A friend of mine passed an inspection with a frozen caliper....but meaty brake pads.
Either way...sounds like an axle...
Old Jun 13, 2011 | 02:18 AM
bigjoe502's Avatar
Thanks for the help. Brakes are this weekend so I will update what...if anything...Changes.
Old Jun 17, 2011 | 06:28 PM
bigjoe502's Avatar
Well started the brakes but before I got too far I put the car on jack stands and ran it in first gear while turning the wheel lock to lock...
The new drive shaft was defective... A visible wobble and noise from the inner cv joint.
Thanks again for all the help
lopezchris21
14
Aug 10, 2008 06:57 PM
serious
Jul 19, 2004 11:11 AM
doh boy
13
Dec 3, 2003 04:17 PM
ghettols
14
Aug 15, 2003 12:52 PM
XLEntropy
Feb 13, 2003 01:06 PM
