Suspension Questions!
Old Jun 10, 2011 | 07:35 AM
jdmdood's Avatar
Icon2 Suspension Questions!
I got a few questions about my EF.. Every time i make sharp turns and i hit bumps my steering wheel just goes crazy shaky!
Ive told a couple of my friends that are builders and they say it might be my rack&opinion (however you call it) but i honestly don't know.
I know my shocks are out bc i bounce all over the place.
If anyone has an idea please do tell, i am thinking of doing a whole suspension makeover for my car before i do an engine swap.
I really don't know much about suspension that much but i want a stiff and slammed ride, i plan on doing some tugging in the future.
Any help will be appreciated, Thanks!
Old Jun 10, 2011 | 07:48 AM
4g4dcruisin's Avatar
Default Re: Suspension Questions!
One thing that is overlooked a lot are the wheel bearings. A quick way to test is to jack up the car, and grab the top/bottom of the tire, wiggle, and if you have play, you're wheel bearing is shot.
That will cause all sorts of vibration, that, and alignment issues.
Old Jun 10, 2011 | 07:51 AM
jdmdood's Avatar
Ahhh so if i wiggle and it wiggles with me (lol) its the bearings are no good?
Thnx for suggestion
I recently did my alignment too, hmm i ponder..
Old Jun 10, 2011 | 07:52 AM
ThatRicerDaniel's Avatar
Usually you can hear a wheel bearing. Probably just a bunch of old crusty busted bushings.
Old Jun 10, 2011 | 07:54 AM
Thnx for suggestion
Yea there shouldn't be any wiggle room when the tire is up off the ground. I'm not too familiar with the rack and pinion, i've never had to replace one or work on one.
jdmdood's Avatar
If this helps.. My car does not make those nasty crank noises when i turn, one of my friends EK hatchy does that.
Old Jun 10, 2011 | 07:57 AM
jdmdood's Avatar
@ThatRicerDaniel - I wouldn't doubt that either, I am literally the 2nd owner and the original did not change anything at all from what i can see.
@4g4dcruisin - Ahh ok, i will test it out and see what results i get.
Old Jun 10, 2011 | 08:02 AM
If you are talking about the click noise that would be the axle boot.
Old Jun 10, 2011 | 08:05 AM
jdmdood's Avatar
Yeah i guess its a click but it sounds horrible on my friends car i literally feel like the car is just going to slam to the ground haha
But yeah, no such noises on my car just very bad under steering and play in my steering wheel when i turn and hit bumpy roads..
Old Jun 10, 2011 | 08:07 AM
Power steering or not?
It probably is your steering rack if you're having excess motion in the wheel.
Old Jun 10, 2011 | 08:10 AM
jdmdood's Avatar
No power steering.. Hmm i will look into the steering rack as well.
dj626
Jun 30, 2005 07:21 PM
akteamster
26
Feb 27, 2005 10:11 AM
StrangerWitCandy
Oct 28, 2004 05:27 PM
Joseph Davis
Jan 30, 2004 06:41 AM
Jet Black
48
Jan 8, 2004 08:12 AM
