What comp. Ratio?????
Old Jun 9, 2011 | 08:06 PM
Snail-werks's Avatar
Default What comp. Ratio?????
I need some suggestions on what comp ratio should I run..I plan on making 750hP+ w a s366 w compR wheels and on c16,w a golden eagle sleeved 84mm ls block and a built head...I was planning on running the cp's 9.7-1 but I also seen people go w higher compression..need some inputs guys..thanks
Old Jun 10, 2011 | 05:33 AM
4cylfiend's Avatar
Default Re: What comp. Ratio?????
I would run 11.0-12.5:1 if you are strictly going to be race gas. The compression will help a TON!
Old Jun 10, 2011 | 05:37 AM
4cylfiend's Avatar
Jeff evans has mentioned to me in email that he builds his race engines at 11.0-12.0:1. For e85 he recommends 11.0:1.
Old Jun 10, 2011 | 06:26 AM
mar778c's Avatar
Community Builder
Community Influencer
This. Plus big cams.
Old Jun 10, 2011 | 07:13 AM
I have pro 1's..and thanks for the input guys...I think to get used to the new setup I'll be running 100 octane and then strictly race gas...any more suggestions?
Old Jun 10, 2011 | 07:54 AM
4cylfiend's Avatar
I wouldnt push it too hard on 100oct.. Dont want to take a chance of detonating. Im not sure of the power level you want to cut off at using 100oct but its just not worth taking a chance.
Old Jun 10, 2011 | 08:09 AM
I was thinking like around 500ish just to get a feel of the car..
Old Jun 10, 2011 | 08:24 AM
4cylfiend's Avatar
That would work.
Old Jun 10, 2011 | 08:28 AM
allmotorCRX.'s Avatar
Should be a nice setup 11:1 ftw
Old Jun 10, 2011 | 08:43 AM
Thanks for the info...anymore suggestions tho
Old Jun 10, 2011 | 08:48 AM
4cylfiend's Avatar
Ignition will play a significant factor. What does your ign setup look like?
Old Jun 10, 2011 | 09:36 AM
Stock for now but I'm planning On getting an m&w setup
Old Jun 10, 2011 | 09:39 AM
4cylfiend's Avatar
Nice! I have the M&W Pro10 and the Msd HVC coil.
Old Jun 10, 2011 | 01:01 PM
Is this ignition system holding up pretty good?
Old Jun 12, 2011 | 02:39 PM
4cylfiend's Avatar
I havent installed it yet. I am waiting for some fab work before I wire everything up
Old Jun 13, 2011 | 09:41 AM
Any more suggestions???
ej1bseries
18
Sep 19, 2011 04:30 PM
o0o_tylor_o0o
Dec 7, 2010 07:03 PM
brookliner7
Dec 7, 2004 06:59 AM
11sec CR-X
Sep 19, 2004 08:24 PM
flip1199
Aug 11, 2004 08:10 PM
