vibrating shifter wont go away
Old Jun 9, 2011 | 06:33 PM
swizz977's Avatar
Default vibrating shifter wont go away
i changed the shifter, still vibrated..
i changed the whole shift linkage, still vibrates!!!!
i dont get it anyone have any ideas? its a 92 civic si hatchback stock
Old Jun 9, 2011 | 10:18 PM
JDMxTai's Avatar
Default Re: vibrating shifter wont go away
I hope you didn't tell your girlfriend about the shifter problem.......
But, make sure shift rod, linkage isn't hitting Exhaust pipes.
Check if shift rod bushings are bad, and check the lower shifter bushing.
Check motor mounts next.
Old Jun 9, 2011 | 11:44 PM
EJ1_CRIS_909's Avatar
Old Jun 10, 2011 | 03:36 AM
NACvicSi's Avatar
Did you change out the bushings? I would get a shifter/shift linkage poly busing kit. Also are you sure you have everything tightened up properly? Replace the b***h pin?
Old Jun 10, 2011 | 03:46 AM
swizz977's Avatar
i changed everything i put a whole new linkage in... its not hitting the exhaust... what would the mounts have anything to do with it?? i figured it was the tranny thats causing this
Old Jun 10, 2011 | 06:32 AM
Former User's Avatar
Check all motor/transmission mounts. They dampen engine/transmission vibration that can be felt in the shifter.
Old Jun 10, 2011 | 06:36 AM
BigMike0147's Avatar
Boom....
Old Jun 10, 2011 | 07:14 AM
diversity210's Avatar
Its most likely the front lower torque mounts. Those things are known to go bad on hondas and they dampn a lot of the vibration from the tranny and engine. Check those and if they are bad change them. Check all of the other mounts as well, but in this case since you are getting vibrations through your shifter its probably those front lower torque mounts.
Also if you are using aftermarket mounts like hasport or avid. That could be causing it too. Especially the ones with the race or track inserts. They are solid mounts and the urathane is a lot harder than the OEM mounts. Which allows a lot more vibrations to disperse through the chasis.
Old Jun 10, 2011 | 09:31 AM
Go_Race_Your_Self's Avatar
Two Piece
10 Pts for Ron
Kev
Old Jun 10, 2011 | 09:36 AM
swizz977's Avatar
oh ok so i guess ill change those 2 lower torque mounts since they look pretty bad and see what happens.. i really thought my tranny was bad or somthing.. i didnt know bad mounts would make my shifter vibrate
Old Jun 10, 2011 | 09:38 AM
Check all the mounts - right and left torque mounts, driver-side mount, transmission mount, and rear mount.
Old Jun 10, 2011 | 12:29 PM
swizz977's Avatar
actually i might of made a mistake when i say vibrate.. i dont mean vibrate at all.. i meant rattles sorry about that.. i wonder if this changes anything.. it rattles a lot when im going past like 3000 rpms but anything under it doesnt or when im in neutral it doesnt only when im going past 3k and i hit the clutch and then it stops
Old Jun 10, 2011 | 12:48 PM
grumblemarc's Avatar
The Grumpiest
What is rattling exactly? The shifter or the shift ****? Is the shift **** aftermarket?
Old Jun 10, 2011 | 01:22 PM
95EG2's Avatar
either worn busings in shift linkage or one or more motor mounts
Old Jun 10, 2011 | 03:01 PM
swizz977's Avatar
no its not the ****.. and i changed out the whole shift linkage so its not the bushings on the linkage i dont think unless they were both bad?
Old Jun 10, 2011 | 03:23 PM
swizz977's Avatar
i think its the bolt where the shifter meets the linkage.. i might need some rubber washers in there maby?
Old Jun 11, 2011 | 02:09 PM
JDMxTai's Avatar
At 3k rpm motor turns faster so motor will move around with bad mounts. So is replace them anyways even its not causeing the problem.
Old Jun 12, 2011 | 08:41 AM
swizz977's Avatar
its not the mounts im trying to figure out why the shifter is making a rattle buzzing sound.. not a feeling vibration sorry for the misunderstanding
Old Jun 12, 2011 | 01:00 PM
blankskates15's Avatar
I was told if the shifter begins to rattle or vibrate constantly it could be what you guys have already mentioned or it could be the throwout bearing in the trans ??
Old Jun 12, 2011 | 08:31 PM
swizz977's Avatar
i figured it was the tranny but i mite put it on a lift n rev it in neutral n hav sum1 c
SilasEk9
Jan 10, 2014 07:38 AM
honda2ksi
Transmission & Drivetrain
Apr 15, 2009 08:52 PM
civicsi0721
Feb 25, 2009 07:14 PM
G0crxG0
40
Apr 24, 2006 07:14 AM
nijia555
Apr 23, 2003 01:25 PM
