Idle Problem b16a
Old Jun 9, 2011 | 04:17 PM
eg5b16's Avatar
Default Idle Problem b16a
Hi guys,
I recently took the throttle body off and iacv an gave them a clean with a throttle body cleaner, i put it all back together.
But i accidentally knocked the throttle position sensor so the idle was bouncing up an down, I calibrated the tps back to standard 4.5v WOT 'wide open throttle' and .48v CT 'Closed throttle'
And now i start the car up it will idle fine, but as soon as i touch the throttle it will rev to 3k at idle or when the clutch is engaged,
the car drives fine when in gear.
Heres a quick video -
http://www.youtube.com/watch?v=eGLF0...layer_embedded
btw the car is a eg5 with a jdm b16a
Any help would be much appreciated
Cheers
Old Jun 9, 2011 | 04:34 PM
fourthgenhatchB17's Avatar
Default Re: Idle Problem b16a
Did you spray cleaner inside the IACV? I usually spray it on to a rag, then just wipe the screen down. I never spray it inside the IACV as Ive never had good luck when doing that. Easiest and fastest method of troubleshooting would be to find a known good IACV and swap it in.
BTW, u must have knocked into the TPS pretty hard to make it move..
Old Jun 9, 2011 | 05:31 PM
eg5b16's Avatar
yeah i did spray inside the iacv, i didn't think that would be a problem.
thanks mate, I'm gonna look for a working iacv an replace it see if that solves the problem.
the tps was a little loose since i replaced the rivets that hold it firmly in place with screws so i could calibrate it.
Old Jun 9, 2011 | 06:35 PM
civickiller's Avatar
Trottle cable to tight? Tb gasket leaking? Sounds like a vacuum leak
Old Jun 9, 2011 | 08:26 PM
Cant be throttle cable since he says it idles fine when initially started.
Old Jun 10, 2011 | 06:36 PM
eg5b16's Avatar
I have found the problem, the throttle rotor with the spring attached is getting stuck at 3,000rpm whenever i touch the throttle, The spring is very loose an need to be tight like this one -
but the problem is the 11mm nut on the rotor just keeps spinning freely an wont come off, which makes it hard to re tension the spring. o well i gotta work over the weekend so ill attempt it again on Monday.
Thanks for the help guys
phelpsj2
Nov 3, 2011 02:35 PM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
V-Thang
Acura TL, RL & ZDX
Feb 24, 2004 02:10 PM
TheHatchHog
May 15, 2003 06:16 AM
