1992 Civic brake pedal sometime goes to floor
I have a 92 Civic that has a bit of a brake problem. This is my girlfriend's car and my dad and I helped her get it and put it back on the road. When we did the brakes we bled them 3 times (in the correct sequence) and they felt great. A few days after my gf got the car the problem started (almost a month ago). What happens is she'll be driving along with the brakes working fine and then one time the pedal has to go almost all the way to the floor for the same braking power as the last time she pressed the brake pedal. Then the next time they go back go normal. Any ideas what it could be? We already ruled out a leak because there are no traces of brake fluid under the car or behind the wheels. Plus, her brake fluid resevoir is full.
reason being is because when the seals begin to wear out in the MC and cannot hold pressure at times, the intermittent pressure lost is one of the symptoms
Yes, it's an internal leak within the master cylinder. I've personally experienced this 3 times now (on 3 different cars). It usually begins to act up when it gets hot out.
On one of the cars, I could actually watch the reservoir rise and fall as the pedal was pushed to the floor and let out again.
Good luck...
Good luck...
[QUOTE=94eg!;45436772]Yes, it's an internal leak within the master cylinder. I've personally experienced this 3 times now (on 3 different cars). It usually begins to act up when it gets hot out
every honda that my friends had that had brake problems stoped once the m/c was replaced
This is the nice part about a hydraulic failure. They tend to be noticeable, but gradual. This gives warning without killing you...
da1lydr1ver
Mar 26, 2012 06:25 PM
about:blank
May 28, 2008 08:21 AM
ThagAnderson
Jun 28, 2007 12:41 PM
dnt94civic
Jun 7, 2002 05:04 AM
master cyl
