Suspension & Brakes Theory, alignment, spring rates....
best sway bar for this setup
Old Jun 8, 2011 | 01:35 PM
jonesvirs's Avatar
Default best sway bar for this setup
Sup guys im using the current setup under my jdm ferio ek 98 sedan
ASR subframe
BEAKS bar
Function7 LCA
Tein Super Street Coilovers
so now im looking into this 2 swaybars and i wanna know wish one is the best and dosnt give trouble to install
*ST
*Progress
*ASR 24mm
*Eibach
lets hear some opinions
Old Jun 8, 2011 | 01:39 PM
98civdx's Avatar
Master Detailer
Default Re: best sway bar for this setup
CTR. 22mm
Are you running a front bar?
Old Jun 8, 2011 | 06:09 PM
PreyStayShun's Avatar
Originally Posted by 98civdx
CTR. 22mm
Ain't that the truth.
Old Jun 9, 2011 | 06:17 AM
jonesvirs's Avatar
CTR. 22mm
i use to have the ctr but when i did the upgrade to the asr it didnt fit also i wan something bigger and aftermarket
in front i have the H brace under and the 3 point carbing on top
Old Jun 9, 2011 | 11:33 AM
98civdx's Avatar
Master Detailer
The CTR bar didn't the ASR!? That's definitely something I have never heard.
I don't believe you can run the Progress bar on ASR's, not 100% positive.
Are you going to run a front a bar? Going bigger then a 22mm rear with nothing in front, could and likely will create quite a tail happy car.
Old Jun 10, 2011 | 05:12 AM
jonesvirs's Avatar
Im going to run a H brace and a bigger front swaybar also
jonesvirs's Avatar
i think im gonna go with the ASR 24mm
Old Jun 10, 2011 | 06:11 AM
alphalanos's Avatar
CTR should fit Ive got one on my 96 sedan with ASR
Old Jun 11, 2011 | 11:48 AM
STOCK_SOHC_DX's Avatar
Unless you're trying to protect your header, don't waste your time with the H-brace
EKSedAndy
Suspension & Brakes
10
Sep 23, 2014 09:40 PM
spoonhbk11
Suspension & Brakes
Oct 10, 2011 06:04 PM
Halo
22
Jan 5, 2005 05:23 PM
Halo
21
Dec 7, 2001 03:28 PM
