Motor bogging on a 92 civic cx
Sorry if i missed the posted about this but my d15b8 bogging out when ever u first give it gas in gear and at 2 or 3 rpm...
cant find out wats wrong wanted to ask
Any info on your issue? My VX is doing the same thing. No CELs but everything is pointing to the o2 sensor, or the EGR system being clogged. Ron, do you have any info on how to clean out the EGR system and lines?
I was having the same problems. I replaced Dizzy Got a accel cap+rotor, Then accel wires, new denso plugs and new fuel pump.. Still didnt fix problem So i checked my ecu and swapped it over 2 a well known CRAPPY D15b8 ecu
And it solved problem. Also found out since i have the y7 head on the b7 block that i had timing off a little lol Cleared it RIGHT Up.. It was a combination of the 2,. I did them at the same time but after i put ecu in i lost ALOT of power cuz its made for a 8valve motor not the 16 valve with bigger injectors. So i swapped back to old ecu and it Messed up Bad, bogging alot and stuff so i know it was the ecu, I opened it up and on the back side some1 had Solderd them selfs and ruining it all and i went to have it fixed and they said its cracked thru the mother board Kids dont need to mess withstuff if they dont know what there doing lol. hope this helps if u havnt already fixed the problem. next on my list... Fuel filter and brakes hahaha
Thanks for the reply tho!
einzelherz
Jun 21, 2012 03:57 PM
keebler65
Sep 21, 2007 09:09 PM
1meangsr
Jul 25, 2003 10:29 AM
