Copper O-Ring Sleeved Block
Old Jun 8, 2011 | 05:56 AM
b00sted EK's Avatar
Default Copper O-Ring Sleeved Block
is it okay to copper spray the head gasket on a sleeved block that uses copper o-rings?
Old Jun 8, 2011 | 08:13 AM
utahturbosohc's Avatar
Default Re: Copper O-Ring Sleeved Block
Yes.
Old Jun 8, 2011 | 01:11 PM
laosonick's Avatar
yep. all day
Old Jun 8, 2011 | 02:23 PM
SPOOLINmatt's Avatar
dont waste your time.
Old Jun 8, 2011 | 03:09 PM
zakura R's Avatar
I always do on my motor is better be safe than sorry my two cents
Old Jun 8, 2011 | 03:28 PM
ive been using copper spray on every engine build ive done for the last 7 years....i all the sudden stopped using it last year and havn't had a single seep from around the gasket since. hmm. Different for others i do understand...but its just never worked out for me. nothing safe or unsafe about it. plus its junked up my radiator with its gunk over time.
Old Jun 8, 2011 | 05:26 PM
KStuned's Avatar
Copper spray just makes a mess. Block and head will be covered in it when you take it apart. I've never had a headgasket failure with OEM or Cometic on my car.
Old Jun 8, 2011 | 06:53 PM
CNC HMA's Avatar
The first time I saw it collected in the oil filter I stopped using it, tore the engine down and found it smeared in a bearing as well. Over 8 hrs ago.
Old Jun 8, 2011 | 07:15 PM
boostontheD's Avatar
this. with a propper decked block and head you should not have HG issues at all with a good HG and proper instalation
Old Jun 8, 2011 | 07:51 PM
h2.4's Avatar
Whoops I meant to quote Reid on his response.
Yep, I agree. I did it once on my engine. when I pulled the head, there was no more copper on the gasket. it was in my cooling system and washed im my oil. Wtf is it good for? ***** that. It's a waste of time. I hear of sooo many people doing it like it's the ****, or it helps. Pull that head and take a look at how cool it's not.
Old Jun 8, 2011 | 08:03 PM
bamboosted's Avatar
like he said aslong as its decked properly.
I never used it and I never had any issues with any cars that came out of our shop!
Old Jun 8, 2011 | 10:09 PM
Boosted_B_Series's Avatar
Very valid points!
We currently honda bond all the oil passages, then lightly coat the front and back of the gasket with copper gasket spray, every car that leaves here
Old Jun 8, 2011 | 11:41 PM
ashtons300zx's Avatar
I never use copper spray on any builds ive done. Its messy and a pain and yeah it will gunk up your cooling system. It doesnt really help. Most gaskets are already coated with special coating to do what the copper spray does and better. Less messy, doesnt get crap in your system. If you have a properly decked head and block and with the o-ring block you should not have any sealing problems at all as long as you torque the head down properly.
Ive never had head gasket failures on any of my builds. Use a good gasket too. I use Cosworth and PE gaskets on all my Nissan stuff and everything else I use a premium gasket as well. Not a big cometic fan as they have sealing issues on their SR20 gaskets. Dont know about the honda ones but I see a lot of people using them on big builds.
I would definitely stay away from copper spray.
Old Jun 9, 2011 | 05:09 AM
b00sted EK's Avatar
thanks for all the input guys.
Old Jun 9, 2011 | 06:14 AM
roadracer4life's Avatar
every gasket every time.. love the stuff.. never a blown gasket ether but that mostly has to do with the tune..
-Sam
Old Jun 9, 2011 | 06:20 AM
bamboosted's Avatar
I NEVER use this stuff. I just make sure everything is clean. Why complicate it more then you have to???
Sometimes when you are trying to be more safe then sorry you end up being more sorry then safe.
This is sgnlab
Old Jun 9, 2011 | 06:29 AM
reactiondc2's Avatar
i prefer hylomar over copper spray...just my .02
grand champ
Sep 29, 2010 08:59 PM
W O T
Feb 13, 2005 10:06 AM
EnjoyTheRideDC2
Jan 27, 2005 08:48 AM
c3p3r
Sep 7, 2003 08:27 PM
Prelude Vtec 23
May 15, 2003 08:12 AM
