D16y7 auto - d16y7 manual swap
Old Jun 7, 2011 | 09:31 PM
bonjoey's Avatar
Icon2 D16y7 auto - d16y7 manual swap
The car is a 98 sedan ex. The orig motor knocks and i decided to swap it with same motor but manual trans. Everything was swapped until i noticed an extra plug in the driverside tower. The orig auto harness has 2 plugs but the swapped motor with manual harness has only 1. The car started fine but i havent driven it yet. I wonder what could that 2nd plug be?
Also instead of wiring the reverse light all the way to the trans, does anyone know where can i wire it up in the ecu?
Thanks
Old Jun 8, 2011 | 04:18 AM
stopspazinout's Avatar
Default Re: D16y7 auto - d16y7 manual swap
you will have an extra plug or 2 left over from the auto harness. and you only have to run the reverse lights from the old auto shifter connector to the tranny, not all the way to the rear lights themselves. but the ecu has no control over the lights.
Killercocopuff
Oct 17, 2011 07:55 AM
Shimakid12
Mar 16, 2010 11:19 PM
Shimakid12
Feb 12, 2010 12:15 AM
GregHr191
Transmission & Drivetrain
Sep 11, 2009 10:15 AM
