Transmission & Drivetrain Gearboxes, Differentials, Clutches
00' Si B16 Trans w/ATS 4.9 FD & Wavetrac LSD Install Questions
Old Jun 7, 2011 | 10:19 AM
jdm jedi's Avatar
Icon6 00' Si B16 Trans w/ATS 4.9 FD & Wavetrac LSD Install Questions
I have a 00' Si B16 trans that I want to have a ATS 4.9 final drive and Wavetrac LSD installed into. The final drive and LSD are the bigger size, meaning they are for GSR/ITR trans. I have purchased the Japanese ITR 1st gear, distance collar, and needle bearing, because that is what the ATS 4.9 needs to install into my trans. I also have a GSR 5th gear (counter and main gear) that I want to put in as well.
My question is, did I get all the necessary parts for all of this to work together? All parts are brand new. As for diff bearings, will I need to have them replaced? I am switching out from a B16 open diff to a Wavetrac ITR LSD.
I'm a n00b to all of this stuff, but have had some of these parts for years and barely getting to finally use it. Thanks for anyone's input!
Old Jun 7, 2011 | 12:42 PM
David @ Synchrotech's Avatar
Default Re: 00' Si B16 Trans w/ATS 4.9 FD & Wavetrac LSD Install Questions
You will also need to replace the diff bearings to the GSR/ITR style bearings.
Old Jun 7, 2011 | 05:07 PM
Trey's Avatar
25 Year Member
Can you pm me where you got your needle bearings for the swap? I have the ats fd in my itr tranny and will rebuild it soon. I would like to use new bearings. Also will you sell your b16 1st gear that you swap with the jdm one? Thanks!
Old Jun 8, 2011 | 07:03 AM
jdm jedi's Avatar
David,
Thanks for your input and help. Synchrotech
Old Jun 8, 2011 | 11:47 AM
Trey's Avatar
25 Year Member
Bueller? Bueller?
Old Jun 8, 2011 | 12:48 PM
jdm jedi's Avatar
Trey, you have a PM!
Old Jun 8, 2011 | 04:14 PM
Trey's Avatar
25 Year Member
Thanks again!
ja20_eg
Feb 7, 2011 11:17 AM
annin
Sep 2, 2006 06:41 PM
annin
May 4, 2005 07:01 PM
