Ugh, '92 Civic VX won't start or crank
Old Jun 7, 2011 | 07:05 AM
PePe240sx's Avatar
Default Ugh, '92 Civic VX won't start or crank
Tried to start it up this morning to take it to a shop to fix the other issues on it, but won't even crank at all. It's for the D15Z1 engine. I'm guessing it's the starter, but could the distributor also cause it as well?
Old Jun 7, 2011 | 07:10 AM
Former User's Avatar
Default Re: Ugh, '92 Civic VX won't start or crank
Have you ruled out a dead battery?
Old Jun 7, 2011 | 07:18 AM
PePe240sx's Avatar
Battery is fairly new, was replaced back in December so that can't be the issue here.
Though I don't have another car to help jumpstart it so I shouldn't rule that out perhaps.
Old Jun 7, 2011 | 07:21 AM
Correct. Have it tested.
Old Jun 7, 2011 | 07:22 AM
PePe240sx's Avatar
I figured it was the starter since the car has almost 242k miles on it.
Old Jun 7, 2011 | 07:26 AM
That's a reasonable guess, but rule out the battery first.
If it's manual, can you push start the car?
If you run hot wires directly from the battery (+) terminal to the two starter terminals, does the starter now crank?
Old Jun 7, 2011 | 08:21 AM
PePe240sx's Avatar
Checked the battery, jumpstarted it but still no go.
I would push start the car but my driveway is too steep to push it back up in case it doesn't start up.
My guess is the starter itself, so I'm just going to pick up a used one locally for cheap.
Old Jun 7, 2011 | 10:08 AM
A bad starter is only one possibility. Doing more troubleshooting could save you a lot of time and money.
For example, do you have a multimeter?
Is the rubber stopper below (red arrow) missing?
Old Jun 7, 2011 | 01:37 PM
PePe240sx's Avatar
Yes! That's what it was. Same EXACT thing that happened to the brake pedal a couple of months ago. Saw a bunch of broken rubber pieces on the floor and looked under it, and that's what it was!
Dude, you saved me a lot of time and money! Thank you!!!!
TerminatioN
Mar 21, 2013 05:29 AM
brzrkr
Nov 25, 2007 03:51 PM
TylerC161
Oct 5, 2006 05:45 PM
dingusjt
Jan 5, 2005 09:59 AM
porkchop14
Sep 28, 2004 09:10 AM
