Fuse box: cooling fan radiator?
Old Jun 7, 2011 | 07:02 AM
ricanxplaya's Avatar
Default Fuse box: cooling fan radiator?
Hey, i removed the fuse box while the battery is dissconnected. because i had to paint the engine bay.
i put the fuse box back on, all the fuse are still intact and good. but now my cooling fan doesnt turn on, the fuse is still good. i jumped wire to cooling fan straight from the battery, it spins. is it possible that the wire from fuse box to cooling fan is bad? any idea, help would appriecated.. its from civic si 00
Old Jun 7, 2011 | 07:04 AM
Default Re: Fuse box: cooling fan radiator?
oh i forgot one thing, i think i read that from honda oem manual book, u must replace all fuses once remove the box from the car. but i dont know if thats true if my fuses are still all good.
Old Jun 7, 2011 | 07:20 AM
Former User's Avatar
Painting the engine bay can interfere with ground wires. Check the G201 fan ground wire connection.
If you unplug and jump the 2P fan switch connector on the thermostat housing, does the fan now run?
Old Jun 7, 2011 | 07:42 AM
ok thanks, i will check on that n post back.
dc97
Oct 18, 2012 08:38 AM
trustdestruction
Mar 30, 2009 06:58 PM
trustdestruction
Mar 30, 2009 03:11 PM
CRIMEIII
Mar 20, 2008 05:39 PM
lilo_goki
Dec 3, 2007 02:47 PM
