Condenser Fan Fuse Problem
Old Mar 30, 2009 | 03:23 PM
trustdestruction's Avatar
Default Condenser Fan Fuse Problem
Recently, I installed a slim a/c condenser fan. Since then, the condenser fan fuse in the under-hood fuse box randomly blows. It doesn't blow immediately, it takes a couple days.
I have checked all of the wiring and it is good.
It's a 1550 CFM, 80 watt, 10" slim fan.
Do the slim fans draw too much power for the 20A fuse that is in the fuse box?
The car is a 93 del Sol Si.
Basically what I am trying to figure out is:
Can I use a higher rated fuse?
If so, what's the highest I can go and still be safe?
Old Mar 30, 2009 | 04:14 PM
non-VTEC's Avatar
Default Re: Condenser Fan Fuse Problem
try a 25amp fuse....
or if you dont feel comfortable running that in the stock fuse box then wire up an extrenal relay to power the fans direct from the battery. make sure you use a high qualitly relay and good wire connections.
Old Mar 30, 2009 | 04:16 PM
Alright, i'll try the 25amp. I don't have any of that rating currently, but i'm now out of 20amp fuses so I better go pick some fuses up at the store anyway.
Old Mar 30, 2009 | 05:02 PM
fcm's Avatar
fcm
Old Fart
Never replace a fuse with a bigger one, find out what the current draw of the fan is, [from manufacturer], I would bet it is less then 20A.
If the fan needs more then 20A of current, install a relay, as mentioned] and use the condenser fan lead to control the relay and draw power for the relay from the batt., fused as required. 94
Old Mar 30, 2009 | 06:58 PM
srmofo's Avatar
you can also measure the amps of the fan and compare them to the manufacturer to make sure it isnt a defective fan. other than that, what he said^
iwannarace
Nov 1, 2014 10:08 PM
demiseraph
Aug 5, 2011 05:12 PM
trustdestruction
Mar 30, 2009 03:11 PM
staticrex
Jul 25, 2005 12:32 PM
b00sted4dr
Jul 25, 2005 05:28 AM
