94 Civic wont start, not getting spark or fuel
Old Jun 5, 2011 | 09:04 PM
ev94eg's Avatar
Default 94 Civic wont start, not getting spark or fuel
i was drivin around an went home an turned m car off went to turn it back on it started but sputtered out an died i changed the plugs wites cap ignition module an valve cover gasket because there was oil in he number one plug and u stil wont get spark and it isn getting fuel
Old Jun 6, 2011 | 05:11 AM
Former User's Avatar
Default Re: car wont start not getting spark
If you hope to get useful replies, then provide all pertinent information about your car and engine:
Old Jun 6, 2011 | 08:44 AM
numberone's Avatar
Bad coil In dizzy.
Old Jun 6, 2011 | 08:46 AM
Originally Posted by numberone
Bad coil In dizzy.
This would not explain lack of fuel.
Old Jun 6, 2011 | 09:15 AM
numberone's Avatar
My bad, I just read the no spark in title.
Old Jun 6, 2011 | 09:18 AM
Well, it's still possible that the coil is bad and there's a separate fuel problem. I just think it's best to start by considering a single problem that could explain both no spark and no fuel.
Old Jun 6, 2011 | 09:21 AM
ev94eg's Avatar
Sorry bout that it's a 94 sedan with the d15b7
Old Jun 6, 2011 | 09:27 AM
Default Re: 94 Civic wont start, not getting spark or fuel
Does the starter crank the engine but it won't start? If so,
Check whether 15A hood fuse 31 or dash fuse 24 is blown.
Clean and tighten the G101 ground wire attached to thermostat housing.
Old Jun 6, 2011 | 09:44 AM
ev94eg's Avatar
All fuses are good and yes the starter cranks
Old Jun 6, 2011 | 10:27 AM
Did you check the G101 ground?
If you unplug the main relay and jump terminal 1 to terminal 7 in the free connector, does the fuel pump run? Likewise, if you jump terminal 5 to terminal 7 and then turn the key to ON(II), does the fuel pump run?
Old Jun 6, 2011 | 10:31 AM
JDM B20 EH2's Avatar
Also sounds to me like main relay. I have also had bad or no ground wire to chassis cause this.
Old Jun 6, 2011 | 10:33 AM
I agree.
Old Jun 6, 2011 | 12:36 PM
ev94eg's Avatar
First thing indid was check main relay. It's still good. Problem is the fuel pump. I finally got spark
Old Jun 6, 2011 | 01:14 PM
What was the solution to the spark problem?
How do you know the fuel pump is bad?
Old Jun 6, 2011 | 01:17 PM
only one side of the main can go bad relay. How did you test the relay?
Old Jun 7, 2011 | 04:39 AM
delsolintegra's Avatar
Could be a intermittent problem with a worn out ignition switch.
When you turn the key put a little inward pressure on the key and jiggle it.
This can give you contact with the fuel pump in key position number 2 and you can hear the fuel pump prime. Seems like 93-95 ignition switches are tending to wear out about now.
turbo gsr2000
Feb 25, 2011 08:40 PM
GrnZ
Dec 31, 2008 07:55 AM
hayn_integra
Oct 23, 2007 10:09 AM
quad
20
Mar 14, 2007 05:16 AM
