CRX won't start
Hey guys as it says my car won't start. I checked the starter it's fine battery is fine. NO CRANK. When i turn the key theres a whirrling noise coming from the starter area, found out it was the positive wire that goes from the battery to the starter. Main relay looks ok, maybe starter relay? The battery is relocated to the back. the positive cable goes into a small little box then splits into the starter/fusebox. When i tried jumping the starter straight from the battery the same thing happened.
ok well i jumped the starter correctly and it worked(off the engine) so i put it back on and hooked it directly to the battery and all it did was click. Took it off and flywheel looks ok, i got a headache :[ Any sugestions?
Well i went to try again, tried jumping with it on block nothing happened just a low whirrling noise. Theres no clutch switch just a bolt. I'm thinkin the battery died just because it hasnt turned on in a while. It turns on lights ecu and all just no attempt to crank :[
