How much HP an ignition box will add.... for the dyno guys
Old Sep 30, 2002 | 07:31 PM
PrecisionH23a's Avatar
Default How much HP an ignition box will add.... for the dyno guys
Well we dyno tuned my car about 2 weeks ago and i put out 330whp at 1 bar of boost, the stock ignition fell FLAT on its face so we could not run the 20+psi that i wanted to. On the dyno graph you could see that the ignition started failing bigtime, and you can kind of feel a misfire at certain rpms. Anyways, installing the crane hi6tr ignition and ps92 coil will add for some power, but how much whp would you say it could add at 1bar?
Old Oct 1, 2002 | 07:42 AM
Default Re: How much HP an ignition box will add.... for the dyno guys (GudeH23a)
ttt
Old Sep 29, 2004 | 08:25 AM
Mase's Avatar
Default Re: How much HP an ignition box will add.... for the dyno guys (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Well we dyno tuned my car about 2 weeks ago and i put out 330whp at 1 bar of boost, the stock ignition fell FLAT on its face so we could not run the 20+psi that i wanted to. On the dyno graph you could see that the ignition started failing bigtime, and you can kind of feel a misfire at certain rpms. Anyways, installing the crane hi6tr ignition and ps92 coil will add for some power, but how much whp would you say it could add at 1bar?</TD></TR></TABLE>
i think you can probably gain 100 whp with just an ignition, newbie
Old Sep 29, 2004 | 08:31 AM
Finest's Avatar
Default Re: How much HP an ignition box will add.... for the dyno guys (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">
i think you can probably gain 100 whp with just an ignition</TD></TR></TABLE>
LOL @ the back from the dead replies!
champLSinteg
Nov 4, 2008 06:33 PM
Johnny_9
Jul 13, 2006 11:16 PM
30psi Teg
Mar 1, 2004 08:45 AM
PrecisionH23a
Nov 17, 2002 09:48 PM
yoshi234
Apr 29, 2002 08:19 AM
