Dead cig lighter
I have a 94 wagon and for some reason the cigarette lighter doesn't work. The light for it doesn't illuminate either. I have checked all of the fuses and they are all fine. Instead of trying to track down where the connection is broken I was thinking of just running a new wire. Does anyone have any ideas of where I could get power from or where the break may be?
Thanks
Thanks
I took the console apart and saw nothing obviously out of the ordinary back there. It could be that the wiring is messed up inside the harness. I don't know as I didn't cut it apart. I'm outside cleaning it right now so maybe I'll take it apart and have a closer looksee.
All of the fuses seem to be good. I'll take a picture of the wiring today. I think the light for the ashtray is out too so it's probably a common cause. As I recall they are on the same branch of the harness.
I'm not sure if this helps, but I found a lighter and wire. It says it will fit your application. Good luck. http://www.autopartswarehouse.com/de...EPU506801.html
