cluster amber turn indicators
Old Jun 1, 2011 | 11:01 PM
ricky00's Avatar
Default cluster amber turn indicators
i was wondering if there was any amber turn indicators instead of the crappy green incators.. i couldve swore i seen ctr's have amber turn signals on there cluster.. correct me if i wrong though.. but just wanna know if there are any out there cause i would like to buy! its for my eg cluster by the way
Old Jun 2, 2011 | 02:49 AM
grumblemarc's Avatar
The Grumpiest
Default Re: cluster amber turn indicators
No. Not possible.
Old Jun 2, 2011 | 08:35 AM
apexi_rsx's Avatar
u could possibly if u take the cluster apart there is a laminated colored sheet behind the bezel. you could make one yourself with a color binder tab you would need to trace ,draw, or print your arrows onto the colored plastic. then cut the old turn signal oval out so u can just tape or glue your new one onto the back of the stock warning light plastic slide. definitely would have to be a diy and this definitely will not look as good as stock most likely but could look decent if done corectly.
mortificationrock
65
Feb 26, 2010 08:39 PM
lkwdscr7
Mar 19, 2009 03:51 PM
kcrxxx
Jul 27, 2007 01:42 PM
BlckBeautyVTEC
Nov 9, 2003 12:33 AM
itsJDMyo
14
Oct 19, 2003 05:22 PM
