a/c works only when condenser relay is removed
Old Jun 1, 2011 | 10:22 PM
Jaynik's Avatar
Default a/c works only when condenser relay is removed
My a/c compressor USUALLY won't come on (it will click on once in a blue moon)
I have gone through the electrical flow chart in the helms manual and found nothing unusual.
I notice, however, that the a/c compressor only comes consistently on if I remove the condenser fan relay. Is this normal or am I near the root of the problem?
btw put in a new relay - no fix.
1997 Civic CX 3 door
Old Jun 2, 2011 | 12:04 AM
Jaynik's Avatar
Default Re: a/c works only when condenser relay is removed
UPDATE grounding the blue and white wire at the A/C thermostat connector makes the compressor come on. Replace thermostat you think?
Old Jun 2, 2011 | 04:08 AM
cwritten's Avatar
I had this issue a while back. I have replaced everything except my compressor. ALL NEW LINES AND COMPONENTS minus the compressor. I did this due to the fact that my 93 was R12 and converted to R134a and they didn't flush the system properly before adding the new freon and Pag oil. I tested everything multiple times and it wouldn't turn on but every once in a while and it would blow ice cold when it was on. then it would shut down and my idle would go up like the compressor was still running. finally I bypassed the thermo switch on the compressor...it's a single red wire that runs from the AC relay to the Thermo switch and then to the AC clutch. I've had to do this on multiple honda compressors now and it's cheaper and easier than buying a new compressor.
****YOU NEED TO MAKE SURE YOUR SYTEM HAS THE CORRECT AMOUNT OF FREON AND PAG OIL AND THAT ALL OTHER PARTS ARE IN GOOD WORKING ORDER BEFORE YOU DO THIS!!!*****
Old Jun 2, 2011 | 05:51 AM
Former User's Avatar
With the A/C on, does the condenser fan also fail to run, even when the fan relay is plugged in?
Old Jun 2, 2011 | 12:46 PM
Jaynik's Avatar
the fan runs and compressor doesn't with the relay IN, the fan stops and the compressor goes with the relay OUT.
Old Jun 2, 2011 | 01:14 PM
Even with the fan relay installed? If so, test the thermostat:
Old Jun 7, 2011 | 11:19 AM
Jaynik's Avatar
shoot, if I have to pull the thermo i'm just going to replace it. I'll let you know what happens.
Old Jun 7, 2011 | 11:24 AM
The reason to test the thermostat is that the problem also could be the heater control panel or a faulty wire.
bfebound
Honda Civic (2001 - 2005)
Aug 6, 2013 07:31 PM
akb427
Jun 28, 2013 08:51 AM
93integrastock
Aug 8, 2007 12:41 PM
7rrivera7
Sep 16, 2006 05:19 PM
