what plugs are good for boost?
Old Jun 1, 2011 | 06:13 PM
bowtieboy911's Avatar
Icon2 what plugs are good for boost?
what spark plugs are good for a BUILT b16 running high boost and what gap? not sure how much boost i will be running until it gets tuned but probably around 20lbs...
Old Jun 1, 2011 | 07:09 PM
Turbo-LS's Avatar
Default Re: what plugs are good for boost?
boost means nothing without a setup rundown. 20 psi on a small turbo could only net you 300whp vs 20 psi on a huge turb would net you 600+whp. up to abotu 400whp heat range 7 is good, after that an 8 or 9 would be needed. higher number colder plug. BKR7E is where you want to start for 400-450whp
Old Jun 1, 2011 | 07:59 PM
pcguy760's Avatar
x2 @ Turbo LS
Old Jun 1, 2011 | 08:22 PM
hamma-head's Avatar
i use ngk bkr8exi part number 2668 .. gap 16 i run 30psi on 93 and 5050 meth all day long and never have had a prob
Old Jun 1, 2011 | 08:26 PM
racebum's Avatar
what compression is this built b16 even at? starting with a 7 and then inspecting to see which way you should go is one way to go about it
Old Jun 2, 2011 | 03:45 AM
Turbo-LS's Avatar
16 gap, stock ignition?
Im running a 32 gap @ 400whp pump gas 93 on brk7e plugs but im also running a summit capacitive discharge box and crane ps92 coil
Old Jun 2, 2011 | 06:00 AM
pcguy760's Avatar
Thats what I was thinking too and he's using the iridium ones which should allow for an even bigger gapping. I switched to brk7e after the recent build with a 25 gap but I have msd ignition, wires, coil so I'm wondering if I should use a bigger gap...
Old Jun 2, 2011 | 06:35 AM
Turbo-LS's Avatar
What MSD box? The regular boxes like 6a, 6al, sci dont like alot of gap from my experience, but if your running a CDI6 or 7 then you can widen the gap up a little if you dont get spark blow out
Old Jun 2, 2011 | 06:51 AM
pcguy760's Avatar
(Sorry OP not tryin to thread jack as I'm sure this will help you sometime too)
LS, its a SCI box...
Old Jun 2, 2011 | 02:43 PM
Turbo-LS's Avatar
then i would personall;y keep the plug gaps where your currently at. You can try going up, worst case is you get blow out and have to gap them back down
Old Jun 2, 2011 | 02:53 PM
pcguy760's Avatar
Old Jun 2, 2011 | 04:58 PM
its 8.5-1 compression... and the turbo i am using for now is a precicion3431E turbo 57 but i was looking into the denso iridium plugs 2 steps colder??
Old Jun 2, 2011 | 05:30 PM
sanman000719's Avatar
BKR7E amen
Old Jun 2, 2011 | 05:41 PM
theyre only 18 bucks for 4 of them? thats a good price
Old Jun 2, 2011 | 07:25 PM
rich7777's Avatar
I use NGK R5671A plugs. As long as your not using the Hondata S300 there all good....
Old Jun 2, 2011 | 07:35 PM
i still dont know what im going to tune on i would like to use hondata but not sure which one
Old Jun 3, 2011 | 07:46 AM
pcguy760's Avatar
It all depends what features you want and how much you want to spend. You do not really need an S300 unless you plan on doing your own tuning, etc. (it has on-the-fly tuning which is nice to have but only in the right hands otherwise you can make your car go boom lol).
I think the Hondata S200 (WITH boost, datalogging and 2-Step) is a nice option for most people.
Old Jun 3, 2011 | 07:56 AM
yeah i got it tuned with chrome pro before but i am probably gonna go with hondata i would like to get launch control maybe that no lift shift or they call it full throttle shift
Old Jun 3, 2011 | 08:24 AM
pcguy760's Avatar
Crome Pro has 2-Step if thats what you're looking for.
Boostinb20!
Jul 16, 2009 02:33 PM
ef dino
Oct 22, 2007 04:46 PM
vangc6780
Apr 9, 2006 04:35 PM
u_tal
Nov 10, 2004 03:01 PM
eg2turbo
Jan 30, 2003 07:38 PM
