VTEC solenoid bolt
Old May 30, 2011 | 08:44 PM
minvi's Avatar
Default VTEC solenoid bolt
I have a 97 Acura CL. I'm trying to get that bottom bolt off of the VTEC solenoid. It is difficult to get a socket in between the walls of the body of the solenoid. A wrench barely fits and I am afraid of rounding off the bolt. Any tips?
Thanks,
Tim
Old May 31, 2011 | 08:19 AM
david78's Avatar
Default Re: VTEC solenoid bolt
I think that it would be better that you consult a good mechanic.he can help you out.
Old May 31, 2011 | 11:29 AM
minvi's Avatar
Any suggestions?
Old May 31, 2011 | 10:55 PM
holmesnmanny's Avatar
I don't know the car but universal joints are helpful in situations like that. I didn't use to use them but now they're a godsend at times. Also, try using some PB beforehand and let it sit.
Old Jun 4, 2011 | 03:04 PM
minvi's Avatar
I was able to get the bolts out.
Here for reference is what I used:
For the top two bolts, used a 'thin-profile' 1/4 drive ratchet with the 1/4 10mm socket. The 3/8 10 mm socket wall is too thick.
For the bottom bolt, I used a 10mm 'midget' wrench. Anything longer banged up against the transaxle. All tools Craftsman.
Also be careful not to tighten too much. A broken bolt in this position would be a real pain to get out.
Tim
chasebur
Honda CR-V & Element
Jan 7, 2019 05:25 PM
pmey
Feb 9, 2009 02:02 PM
Methane2k2
Dec 15, 2004 12:57 AM
notstock93
Mar 1, 2004 06:40 PM
shadowstylz
Sep 16, 2003 10:20 AM
