NEED HELP!!!!!!!!!
Old May 30, 2011 | 08:31 PM
dizzlebB's Avatar
Default NEED HELP!!!!!!!!!
so my 88 ef d15b1 keeps setting code 1 (o2 sensor) put one in and drive drive drive BLOOP! CEL on again "code 1" went to parts store got another one threw it in...... drive drive drive BLOOP cel on "code 1" checked volts to o2 wire and getting .05v at idle 1.0v at quick rev so o2 is working... any ideas? im soooo lost. ive hurd theres a high fail rate on the header cat but before i run out and buy a header i wanna know what you guys thoughts are
any help will be helpful.... (DUH!! LMAO)
Old May 30, 2011 | 08:43 PM
sirtef9's Avatar
Default Re: NEED HELP!!!!!!!!!
Bad cat maybe?
Old May 30, 2011 | 08:51 PM
Dennis_Dtec's Avatar
Well.. one thing that I am noticing.. is you not mentioning of clearing the code once you changed the part? Did you reset the ECU? If not.. its still stored and will cotinue to throw the code.. doesn't self recognizes the part being changed.. you have to do it.
YaBoiTHiZZ
12
Mar 28, 2012 08:10 PM
DJ Gurgla GSR
May 30, 2006 12:50 PM
impr323
Jun 21, 2005 05:29 PM
notfastenough
Nov 11, 2004 04:31 PM
S13 slide
Dec 1, 2002 06:44 AM
