9:1 or 11.1 on a 6262
hey guys im building my motor again and have my old 9:1 cp pistons, but got a set of 11:1 cp pistons too, i was woundering if i should do high comp with less boost since im uesing a 6262 with a 82ar, the block is bing sleeved from erl so i would appreciate u guys inputs would like to get the most power out of the setup
whats your definition of "the most power of the setup"?
whats the power goal, what is the car going to be used for? DD, season drag? planning on having the car reliable? Pump gas? race gas?
11.1 compression with a turbocharger is a ticking time bomb, especially if its going to be Daily Driven on pump gas. thats why you dont see many people turbocharging a stock type r engine ( i say not many, because there are a couple builds here on HT like that ).
thats why everyone opts to lower compression for the ability to bring up boost pressures. As shawn church told me, it makes tuning a little easier, because the higher the compression, the less room for error there is.
but it all depends on your goal for the car. for "the most power" the 11.1 is going to make "more power" than the 9.1 counterpart at the same boost levels, but its also going to have higher cylinder pressures.
TheShodan should be here soon enough to clear it all up. Youre going to have to provide more details though
whats the whole setup? supporting mods?
Thanks for info but the car is for the track only the set up is a Full gsr,the head has skunk2 valve train with Mazworx turbo cam, the block is being sleeved at erl for 81mm stock bore, the crack has all color coded bearing from Honda,turbo 6262 82ar top mount 44 mvr wastegate, fuel is a 255 intank and a 044 inline 8am freed and 6am return with 1600 injectors automotive fuel regulator Aem fuel rail, the car is on Aem and has boost by gear, already made 550 on 20psi but wanted more power so I took the block to get sleeved, want to get like 650 or more
run the 11:1 and dont back off the boost.
Just treat it like any other engine. Unless you are building a street gas car, its not going to be a ticking time bomb and will perform just fine at even 30+ psi
I'd want something right between 9 and 11:1 if your ever going to run pump. If strictly race maybe go 11:1 if more likely always pump go 9.
Both will be a compromise to some extent. Sell both sets of pistons and buy 1 suitable set.
we have a car thats tuned for 500 on 93 octane and 700 on race gas....11.1:1 comp and it runs just fine.
if you can switch the tunes around with a laptop then youll be fine.
i take that back its 11.5:1 i must have misheard what my engine builder said. here you go 30-31psi mustang dyno
http://www.youtube.com/watch?v=SUL-s...layer_embedded
RichD14
Nov 13, 2016 12:34 PM
