97 5th Gen Loose Shifter no 1st or reverse
Old May 29, 2011 | 05:40 PM
97RudeLude's Avatar
Default 97 5th Gen Loose Shifter no 1st or reverse
Hey forum.
I need some help. My fifth gen's shifter just went loose. It goes into all gears except 1st and reverse, is it my syncros?? Or what thx for your responses
Old May 29, 2011 | 09:09 PM
bigblue7t6's Avatar
Default Re: 97 5th Gen Loose Shifter no 1st or reverse
Pull your center console out and expose the shift linkage, sounds like something there, or possibly right at the transmission has came undone or a bushing has fell out and isn't giving you range of motion. After installing a short throw shifter in my car in a hurry, I carelessly left one of the shift cables loose from the bracket it snaps in on top of the base at the shifted and I had no reverse because there was too much play for it to correctly pull on the levers of the transmission
Old May 30, 2011 | 12:03 AM
97RudeLude's Avatar
alright yea, instantly i assumed it was probably just the bushings or i knocked something off loose, im hoping thats all it is, thx for your help
Old May 30, 2011 | 09:37 AM
xOtakuBuster's Avatar
It could just be the bushings, either way once you figure it out let us know.
Old Jun 1, 2011 | 10:11 PM
97RudeLude's Avatar
Yea im gonna flush her first and then check the cable connections
SacrificeTheory
Honda Civic (2006 - 2015)
11
Jan 7, 2008 07:09 AM
matix
Jun 15, 2007 03:45 PM
kornerk12
May 30, 2006 08:00 AM
raylude
Jan 7, 2006 02:42 PM
RFX
Jan 24, 2002 09:32 PM
