Loud metal sounding grind / squeek w/ steering and susp
Old May 29, 2011 | 11:50 AM
acanby's Avatar
Default Loud metal sounding grind / squeek w/ steering and susp
my 1993 prelude has had the power steering rack replaced and the front upper ball joints and tie rod ends, and when i turn my wheel it squeeks loud and consistently. And when i hit bumps it squeeks, and the shocks feel stiff, i just didnt know if it was my shocks were bad and that was causing the steering squeeks and suspension. Could it be a bushing ? I know alot about the motor and stuff now cuz i did a motor swap on it, but i dont know much about the suspension. Thanks alot
Old May 30, 2011 | 12:17 PM
razorlude's Avatar
Default Re: Loud metal sounding grind / squeek w/ steering and susp
all the symptoms u describe sound exactly like a bad upper arm ball joint though..... how u did that change when it's "welded" on the stock upper arm?
Old Jun 1, 2011 | 08:52 PM
acanby's Avatar
i bought two new upper control arms for the front, sorry i shouldve been more specific. I got new outer tie rod ends, new power steering rack and pinion, and upper control arms for the front. I have the vtec so its 4WS and the rear upper and lower ball joints are shot on both sides, and the rear tie rods. Could that affect it in any way? i know it does with the swerving, but the squeek? and i also forgot to mention that my front lower ball joints are bad still, i have yet to replace those.
hybrid90
Suspension & Brakes
Jul 30, 2019 11:47 PM
sumdewd
Jul 4, 2012 10:52 AM
Andy Hollis
17
Jul 28, 2004 06:04 AM
dpo95si
Apr 24, 2002 03:19 PM
cbrf-3
Feb 5, 2002 08:44 PM
