quick question??
Old May 29, 2011 | 07:43 AM
the white sam's Avatar
Default quick question??
i have a 1989 honda civic dx (hatchback)
i want to lower it, the last thing i wanted to do was cut the spring's
one of my friends gots a set of coilovers, he said hed give me them for 15 buck's (all 4) i wanted to kno if i could just use the springs from the coilovers,and just throw them on my stock struhts?
what do u guy''s think i should do, money is kind of tight, at this time, am saveing cause i got a kid on the way, but anywho, whos got any idea's?
oh ill post some post some pic's tonight for yall.
Old May 29, 2011 | 08:10 AM
vitamin_c95's Avatar
Default Re: quick question??
dont waste your time...do it right the first time
Old May 30, 2011 | 07:52 PM
silber's Avatar
Don't think so since coil over springs are flat and stock has small pig tail. Coil over springs tend to be short so you can drop the car on adjustable spring perch. So don't do it unless it was made for the car. Have a good day, hope you find some good lowering springs!
Old May 30, 2011 | 08:36 PM
Dennis_Dtec's Avatar
Really.. It's 2011... the world almost came to an end on May 21.... and money is an issue for finding lowering springs for a 20+ year old car? Dude.. seriously.. if you have a kid on the way.. get your priorities in order... Projects take a backseat.. little one and momma comes first... that's how you get them on board later on to help you. Anyways, let me give you some idea's. First of all.. what size rims you running? And what's your skill set? Can you do an axle swap.. or your just a Air Filter and Sticker kind of guy? If you are running 13's or 15's and you just want to kill that factory space between the tires.. then yes you can cut the springs.. no more than two coils! If you are running 17's or 18's.. then switch to 15's to run street races.. then you would want the flexability to raise and lower the car.. coil overs are the way to go! The coil springs alone will not work.. as they are a different spring rating and height compared to the factory stuff.. you will need the perch's that they sit on.. you can use the factory shocks though. Hopes this helps.. and congrats on baby! Atleast someone is more productive on this forum.. lol
TonyBlaz
Suspension & Brakes
17
Sep 28, 2012 07:26 AM
JaimmyACA
Nov 26, 2011 09:46 PM
alex14
31
Jan 30, 2011 11:03 AM
wu tang
Jul 17, 2002 06:22 AM
94acurals
Jun 23, 2001 06:52 PM
