Wiper problem
Old May 29, 2011 | 06:56 AM
Slacker93eg's Avatar
10 Year Member
Default Wiper problem
When I bought my car, the green wire by the driver side firewall was cut, I re attached and found out why, even with the switch off, the wipers would stay on. So I replaced the wiper switch, and it worked perfectly for about a month. Just last night, I was turning the wipers on then off just to clear a few drops off. Then suddenly when it was off, it would start wiping again.. does anybody have any idea what's going on here? I don't want to keep buying wiper switches
Old May 29, 2011 | 11:43 AM
10 Year Member
Default Re: Wiper problem
To the top! It's rainin like a bitch here! One speed - slow as *****, I need some help here lol
Old May 29, 2011 | 11:52 AM
Former User's Avatar
93 hatchback? So do the wipers run on intermittent, low, or high speed? If you unplug the wiper switch plug, do the wipers stop running?
Old May 29, 2011 | 11:53 AM
10 Year Member
I have not tried that yet, would that be the diagnosis of a bad switch?
Old May 29, 2011 | 11:57 AM
Do the test, post the results, and we'll go from there.
Old May 29, 2011 | 12:03 PM
10 Year Member
Sounds good, i'll post back once I get around to it
Old May 29, 2011 | 12:04 PM
Old May 29, 2011 | 12:07 PM
10 Year Member
Well, the intermittent speeds weren't really that different when the switch was working "right", but right now its stuck on low speed
Old May 29, 2011 | 12:09 PM
93 hatchback? Before you replaced the switch, was it also stuck on low speed?
Old May 29, 2011 | 12:14 PM
10 Year Member
Nope, before it was high
and yes it's a hatch
Old May 30, 2011 | 06:55 AM
Sleepek24's Avatar
Im in the same boat but only difference is that my rear wiper wont turn on.
Old May 30, 2011 | 07:37 AM
That's a different boat. If you want help, please make your own thread.
Old Jun 2, 2011 | 12:45 PM
10 Year Member
I took apart the switch, there is a little arm that slides a plastic piece with 2 electrical connections on it when you switch from Off/Slow/Fast. The little arm was broken. Looks like I just need to go buy another switch and inspect that little arm before I buy it.
NRMEUV1
Apr 8, 2012 03:29 PM
Phildo916
Mar 23, 2010 12:51 PM
slambedcivic
Feb 3, 2010 01:44 PM
96gisar
Dec 21, 2007 02:02 PM
ferio 95
Mar 3, 2005 04:47 AM
