problems with s300 over crome
Old May 28, 2011 | 10:13 PM
MONSTERek4's Avatar
Default problems with s300 over crome
set up is
ls vtec
id1000cc
golden eagle sleeve 85mm
type r head
walbro 255
car drives fine and everything but as soon as it reads boost it breaks up bad. ive changed plugs 3 dizzy and now added msd and it seems problem got worse so i try crome on it and it went away.... ive tried 2 different s300 on it any ideas 1 of the s300 is a known working one
Old May 28, 2011 | 10:14 PM
MONSTERek4's Avatar
Default Re: problems with s300 over crome
and before someone says post a datalog... the datalog does not show the break up
Old May 28, 2011 | 11:11 PM
mouab18c1's Avatar
More tuning?
Old May 29, 2011 | 04:24 AM
mtber's Avatar
What air fuel ratios are you observing when this occurs?
What plugs are you running at what gap?
Is your car reporting any malfunction indication codes?
Post up the s300 calibration you are using & the crome binary file.
Old May 29, 2011 | 10:27 AM
MONSTERek4's Avatar
im runing 9's 1 set gaped at 25 and i tried another set at 15 and afr i tried 11.2 11.5 11.8 12.1 it sputters still i even did a lean pass at 13.1 and still sputter i also did a leak down and all 4 cyl wer 35% not sure if that matters on ignition
Old May 29, 2011 | 10:32 AM
MONSTERek4's Avatar
how the hell do i post the bin can i just email it to you
Old May 29, 2011 | 11:02 AM
mouab18c1's Avatar
Take a screen shot of all your maps!
Old May 29, 2011 | 11:35 AM
SpokaneSpeed's Avatar
and a screenshot of your calibration settings
Hondaspeed5540
Aug 15, 2008 08:19 PM
dan_w_82
Aug 1, 2006 03:54 AM
*Boostwerks*
Jan 16, 2005 02:26 PM
GDM Z28
Nov 17, 2003 11:09 AM
hybridb18
Jul 8, 2003 07:05 PM
