91 si with 90 ls integra brakes
hello,
i recently perchased a daily driver 91 si. it has 1990 integra brakes and suspention with ground control springs/agx shocks. getting off topic but my question is my brake master cup seals are bleeding down. im getting ready to purchase a new master and was wonder in should i get an integra master? was told the one in the car is stock along with the proportioning valve? im a honda newb, my backround is toyota nissan.
thanks
tim
thanks
tim
For the best results I would try to source the 1990 Integra master cylinder, booster, and 40/40 proportioning valve to match the brakes on your car. As a result this would enable the brakes to function at their best.
You are correct
The Integra uses a master cylinder that measures 15/16"
On the other hand the civic uses one that measures 13/16"
In this case you would need to get the Integra brake booster
You will notice a stronger petal as well when it comes to stopping.
Good luck with your project!
If you need anything PM me
John
John
Use the search function at the top of this page.....thats why its there.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/easiest-brake-upgrade-you-never-knew-about-details-inside-1171175/
Cyrus4g63
Mar 10, 2006 08:35 AM
Tbindas
Jun 8, 2005 08:30 PM
i did rear disk conversion...is integra brake master cylinder 7/8 good enough?..and wat emergency ca
fastest
Jun 9, 2004 08:54 PM
Torino91LS
12
Mar 14, 2003 01:54 PM
