Drag/Street Car Fuel System Question?
Old May 26, 2011 | 01:37 PM
2point1's Avatar
Default Drag/Street Car Fuel System Question?
Although this may not be the proper place to post, I've gotten conflicting answers and need a definitive answer and know you guys can help. THIS IS AN ALL MOTOR SETUP!!!!!!
I have a sumped 12 gallon cell feed with -10 line from tank to Aeromotive 100 micron filter to Aeromotive A1000 pump to 10 micron filter and then changed to -8 line all the way to the fuel rail. Looking into changing the fuel pump to the Walbro 255lph inline pump. The inlet outlet though is 10mm x1.0, I'm wondering if there would be an issues since this pump has a smaller inlet/outlet then the Aeromotive. Summit has the metric to AN conversion fittings from 10mm x 1.0 to -8AN that I would use. I will be keeping the 2 filters setup like I have now, just swapping out the pump. Any input will be greatly appreciated. Thanks
Old May 26, 2011 | 02:26 PM
tony1's Avatar
Default Re: Drag/Street Car Fuel System Question?
Having too big of a fuel line won't hurt anything.
Old May 26, 2011 | 03:23 PM
2point1's Avatar
Thanks for the reply Tony1
I'm questioning going big to small and then to big. Right now it's -10 from tank to filters, pump and filter, the last filter has -8 on the outlet side. The walbro has like a 5/16" in/outlet, whatever 10mm x 1.0 is that's what it has
Old May 27, 2011 | 12:35 AM
2point1's Avatar
Anybody......
Old May 27, 2011 | 04:22 AM
tony1's Avatar
It'll be fine.
Old May 27, 2011 | 01:39 PM
2point1's Avatar
It'll be fine.
Thanks again tony1, your the man
Old May 27, 2011 | 01:53 PM
MrParks's Avatar
pics?
Old May 27, 2011 | 03:45 PM
2point1's Avatar
Originally Posted by MrParks
pics?
what do you want pics of?
Ohgodzirra
Welding / Fabrication
Aug 10, 2007 07:43 AM
Redwidow
Jul 13, 2006 12:51 PM
tygsr
May 11, 2002 04:14 PM
shadowdawn
Apr 10, 2002 05:32 AM
BoostedSi
Feb 4, 2002 03:23 PM
