Jump car at starter
Old May 26, 2011 | 04:04 AM
76 camaro car's Avatar
Default Jump car at starter
My daughter has a 92 accord that quit starting with the key about 6 months ago. However if you put the ignition switch in the run position it will jump off at the starter using two screwdrivers. It will also shut off using the key.Where should I start looking to correct this for her? Thanks
Old May 26, 2011 | 04:42 PM
Default Re: Jump car at starter
Any idea's ? I'm thinking maybe the ignition switch.
Old May 26, 2011 | 08:53 PM
Brownjd's Avatar
pretty sure i would replace the ignition switch and call it a day
Old May 26, 2011 | 11:14 PM
nus_dogg's Avatar
I agree with the other two about the ignition switch.
Old May 27, 2011 | 06:38 AM
arielb1's Avatar
yup, ignition switch..easy enough...I just picked one up at autozone. Lots docs on the web.
Old May 28, 2011 | 07:06 AM
poorman212's Avatar
Test the switch, if the power is coming out and not getting to the starter then something is preventing it.....manual or auto trans.
Old May 28, 2011 | 12:40 PM
phootbag's Avatar
Use voltage drops. Sure, it could be the ignition switch. But, it could also be a faulty starter solenoid. Voltage drops are pretty cheap and can save money.
roxics
11
Oct 29, 2018 10:14 AM
David451
Aug 26, 2015 04:37 PM
carve
Sep 12, 2009 09:35 PM
Un0Turb0-WP
Oct 19, 2004 11:45 AM
