? about welding stainless
Old May 25, 2011 | 12:57 PM
sc34dc4's Avatar
Default ? about welding stainless
I need to extend my intake tube for my turbo inlet. I have everything cut and marked now it just needs to be welded. My friend only has mild steel wire currently. I know typically this is a no go because it will eventually crack. This piece will be seeing no heat except for what is in the bay. So would it be ok? It's going to be painted so I'm not concerned with it rusting. Thanks,Adam
Old May 25, 2011 | 01:13 PM
9bells's Avatar
OG Fabricator
Default Re: ? about welding stainless
The resultant weld would be fine really.
The ferrite number will be less than optimal, but
Without a significant load ( static or cyclical),
Cracking really shouldn't happen.
The paint will minimize the only real concern
For long term use in this case; corrosion related failure.
Old May 25, 2011 | 01:21 PM
sc34dc4's Avatar
Thanks 9bells. In not so many words it'll be fine just make sure I paint it.
Old May 25, 2011 | 02:56 PM
9bells's Avatar
OG Fabricator
Sure.
htsang07
Paint and Body
Jun 11, 2010 04:11 AM
66fasty
Welding / Fabrication
Sep 16, 2007 06:02 PM
CooBlueDAB
Nov 26, 2006 05:17 PM
FragSyndrome
Mar 23, 2004 09:22 PM
redEFnine
Aug 8, 2003 10:28 AM
