a question about paint and priming.
Old Jun 10, 2010 | 05:21 PM
htsang07's Avatar
Default a question about paint and priming.
Hello, i just jb welded something and i kind of want to paint it because it looks kind of strange. I was wondering how well paint goes on jb weld. Would paint or primer stick well onto jb weld?
Thanks.
Old Jun 10, 2010 | 06:48 PM
stevenwillisr's Avatar
Default Re: a question about paint and priming.
Hey, since its a metal surface you will need to primer... And you need to sand the part we're with I say 400 grit to get a good bite for the primer to sick and make sure you wipe the part down with wax/grease remover that's all I can think of. It would help more to know what your painting
Old Jun 10, 2010 | 10:59 PM
gorillafart's Avatar
400 is too fine for primer.
Old Jun 11, 2010 | 02:29 AM
400 grit would be the limit for primer, it all depends on what primer he use's you sure don't want to use 30 grit and scratch the **** out of it
Old Jun 11, 2010 | 03:01 AM
kelsodeez's Avatar
derp resistant
scuff the surface with a scotch brite pad. use a self etching primer on bare metal. then use a high build.
180 for shaping
400-800 for wet sanding
1000-above for buffing clear coat
it should be fine spraying over the jb. as long as there arent any bubbles in the jb. are you using an epoxy based paint or an enamel?
Old Jun 11, 2010 | 04:11 AM
chewyv's Avatar
pm4nudes
depends...what is this "something"
dem0nk1d
Paint and Body
Apr 15, 2011 03:21 PM
dirty19
Paint and Body
Mar 31, 2011 09:28 PM
GoLowDrew
Paint and Body
May 16, 2010 05:21 AM
toojdmforschool
Paint and Body
10
Feb 12, 2009 08:52 AM
ReactioN
Paint and Body
Jul 28, 2008 10:18 AM
