f20b twin cam swap into a civic..HELP
Old May 25, 2011 | 10:08 AM
elcivic11's Avatar
Icon2 f20b twin cam swap into a civic..HELP
ok well i have a civic 99 with an f20b swap. my problem is i did my own harness from an ex civic harness . the problem is that the engine does not want to start up. it fires but wouldnt turn on. i have check the spark and all sparks are receiving.. i have check for the fuel and it is sending all injectors are right .. the only thing that the engine does is that the first piston wants to make the engine start but it will not turn the other 3 pistons are sending the fuel a little burn but still just sending kinda wet ... so i have also check the compression of each cylinder and the lowest i have found was a 180 i dont know it that is good or bad for this type of engine .. and can i also get some diagrams of what are the positions of the injectors and spark plugs please.. because im not sure if i did put them right .. please someone help me out .. pros on this engines PLEASE HELP!!! thanks
punkkid12o3
Honda Civic (2001 - 2005)
Sep 17, 2008 03:22 AM
89bluehatch
Feb 11, 2007 08:16 AM
PiXeL
Oct 16, 2006 05:01 AM
cobrajoe99
Aug 16, 2006 02:27 PM
GhostInTheShell
May 30, 2006 02:31 PM
