Suspension & Brakes Theory, alignment, spring rates....
5 Lug Conversion
Old May 23, 2011 | 11:18 PM
dewey_civic's Avatar
Default 5 Lug Conversion
When doing a 5 lug conversion obviously you need new brake lines (got) new pads (got) new rotors (got) wheel and tires (got) new master cylinder (got) what the questio and topic is getting at.....
When upgrading to a 5 lug do I have to re flange the lines for the new master 1" cylinder I got one off of a 95 teg.
What axles will I be needing for the swap. I have one axle from a b18c1 is that same as b16A2? Or will I have to buy new axles?
Old May 24, 2011 | 12:55 AM
Default Re: 5 Lug Conversion
Let me know if you anything about the different axle sizes. And what axles go with what engine.
Old May 24, 2011 | 04:22 AM
jdmcx's Avatar
you will need itr axles for itr hub.
Old May 24, 2011 | 04:40 AM
Can I Pick those up at autozone? What size are those.
Old May 24, 2011 | 06:01 AM
Dogginator's Avatar
Daisy... Daisy...
USDM ITR axles are compatable with normal 94-01 Integra axles. Some of the JDM ITR axles are a larger diameter.
Old May 25, 2011 | 02:00 AM
What about the Master Cylinder is it a straight swap? I got one from a teg..
Old May 25, 2011 | 04:26 AM
Dogginator's Avatar
Daisy... Daisy...
The ITR MC is a 1" bore. The MC should be marked on the side for the bore. Integras came with 15/16" (non-ABS) and 1" (ABS) master cylinders.
Old May 26, 2011 | 01:20 AM
I got the 1 inch. Is it the same fittings as a 99 dx hatchback?
Old May 30, 2011 | 11:51 PM
Ok so I got a ctr swap as far as the 5 lug conversion goes, will the same b16 axle fit?
Old May 31, 2011 | 03:23 AM
Trey's Avatar
25 Year Member
You need a 98+ itr mc so the brake lines match up. No need to bend or reflange.
Old May 31, 2011 | 03:48 AM
What about the axles?
Old May 31, 2011 | 11:51 AM
Trey's Avatar
25 Year Member
JDM ITRs use 36mm axles vs the USDM ITR using 32mm axles. I dunno about the JDM CTR but assume its the same as the JDM ITR. You might want to ask in the hybrid forum.
Old May 31, 2011 | 04:32 PM
Thanks man
Old May 31, 2011 | 06:43 PM
2000FBPITR's Avatar
JDM CTR are 32mm, you are fine with any USDM B series axle. What chasis is this brake swap going onto?
Old Jun 2, 2011 | 01:17 AM
Ej9. 99 hatchback.
Old Jun 2, 2011 | 01:18 AM
Can I use the booster off the teg and just put my master cylinder on it?
Porsche944Turbo
Nov 21, 2016 02:53 PM
Alfredoem1
Nov 21, 2013 11:47 PM
Boriqua0555
Jun 28, 2007 10:13 AM
jdmjohn02
Jan 11, 2004 07:56 PM
00hatch98r
Mar 29, 2003 04:02 PM
