Engine Swap
To my understanding anytime you do an engine swap there are certain components that cant be swapped...my engine has the ulev plate on it. My question is why cant i do an even swap with more horsepower without all the complications? As far as the AC, power steering and emissions?
1) You don't list what car you have
2) You don't list what motor you want to put in
3) You don't list whether or not your state requires emissions testing
etc
There are plenty of threads in the Accord FAQ regarding swaps, I would suggest reading through those before asking more questions.
1st your engine must be 2000 or newer and that means only 1 year of H22s are available.
Emissions, if all your sensors work properly and your cat does its job you shouldn't have an issue passing emissions.
so yes it is possible.
You will have to stay OBDII then which requires more work than just going OBDI. If you do a search you will find out what you need (ECU, Motor, etc.) You do not want an ATTS based transmission.
You are quite general with the word machining, not to mention you missed the fact that it will do little for a car that can't be tuned to take advantage of it due to strict emissions laws.
Yeah, I do not envy you OP.
blkonblkhatch
Mar 8, 2006 07:15 AM
