automatic shift knob compatibility
Old May 19, 2011 | 07:23 PM
DJKhakiPants's Avatar
Icon2 automatic shift **** compatibility
I have been looking for a stock automatic shift **** for my 98 ex v6 coupe to no avail. Are the newer generation auto ***** compatible? They seem to be more widely available...
Old May 19, 2011 | 07:43 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: automatic shift **** compatibility
I'm guessing you didn't bother looking at the Accord FAQ for some ideas.....
New OEM:
http://www.hondaautomotiveparts.com/...5=SELECT+LEVER
Used OEM:
- eBay
- craiglist
- the WTB/FS thread
- v6performance forums
- junkyard or pick-and-pull
- etc
New aftermarket:
- TAS Auto
- eBay
- etc
To answer your other question you need to be way more specific than 'newer generations compatible'.......your chassis was from 98-02 and all those should be interchangeable. Beyond that I doubt it.
Old May 20, 2011 | 02:54 AM
Yes and no - I spent an embarassing amount of time looking for something using the wrong terminology. Thank you for the link, that is exactly what I was looking for.
Old May 20, 2011 | 05:03 PM
So to restate the original question more clearly - will any selector ***** from models made after 2002 fit the 6th generation automatic shift levers?
Old May 20, 2011 | 05:44 PM
Bwill9886's Avatar
Use the site linked to you by TheMuffinMan and compare how the newer model's shifter ***** are attached (Just select a newer model year in the vehicle selection screen and find the same schematic).
I'm guessing you might have a newer one you could swap for free/cheap laying around? Otherwise you might as well just get the one meant for it.
Old May 21, 2011 | 09:21 AM
Doubt it, IIRC your model has the button on the side. Newer ones have a button on the front, and do not connect nearly the same as yours. You *may* be able to retro-fit it on but I personally wouldn't do it. Just do a Google Image search on what they look like.
Old May 26, 2011 | 03:57 PM
thanks for the input... I can't tell by the diagrams on the linked site how well it would work - outer diameter of lever vs. Inner diameter of the new ****, button orientation.... but the **** for a 2003 model is a fraction of the cost of a 98-02 design. I was hoping someone had tried it. Ebay surprisingly has no oem ***** for this model. Anyway... this will be my 5th post so now I just have to wait it out and I can post a wtb in the appropriate section.
Update: for others that may be looking... the answer is a firm "no" without drilling and modifying the new ****. The outer diameter of the actual shift lever is the same but the length varies and the set screws are in a different place.
JonoBB6
Mar 10, 2011 11:15 AM
Eagle16nam
Mar 19, 2006 06:06 PM
Alibi86
Sep 10, 2005 07:06 PM
social_control
Jun 26, 2003 05:29 PM
Fuster_Cluck
41
Apr 26, 2002 06:32 AM
