Transmission & Drivetrain Gearboxes, Differentials, Clutches
replaced transmission, no reverse? wtf
Old May 23, 2011 | 07:34 AM
DC2_Legend's Avatar
Default replaced transmission, no reverse? wtf
so i replaced my LS transmission to a CTR w/ LSD, i know it works fine because it came from my other car. Which was fine when i took it off. For some reason i can't reverse. I can shift it into (reverse) gear but if i try to accelerate it'll go forward...
Shifter is loose, i mean really loose.. Didnt use the "bitch pin" to connect shift to trans. Didn't have one laying around. Used a bolt and 2 nuts instead. Im guessing that may be the reason why it is loose. Unless i installed something backwards..
help is appreciated.
Old May 23, 2011 | 09:26 AM
David @ Synchrotech's Avatar
Default Re: replaced transmission, no reverse? wtf
Try disconnecting the shift linkage and test shifting it right at the transmission. This will show you if it is internal or a linkage issue.
Old May 23, 2011 | 12:50 PM
Honda Bull's Avatar
Sounds like you are selecting 4th and not Reverse. Is there an audible 'click'?
Pull the shift linkage off to fix your linkage to trans issue (no spread pin). You need the correct diameter bolt/pin to go through there or it will have slop and not rotate on the lateral, neutral axis enough to select the left and right shift gates. While you have the shift linkage disconnected, do as Synchrotech says and test shift the transmission without the linkage and make sure it can select Reverse (from behind the transmission, rotating shift rod clockwise, and pushing forward).
Matt_Jagg7
May 13, 2010 01:18 AM
umair
Mar 27, 2009 03:27 PM
itismejoshd
25
Sep 25, 2007 05:16 AM
ALLMOTOR CRX
11
Mar 29, 2007 07:34 AM
honda4674
Jun 24, 2006 12:45 AM
